Idling Vibrations - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 08:51 PM   #1 (permalink)
View frankl's Photo Gallery
Idling Vibrations
Hi how do you guys rate your engine vibrations when idling at the stop light?
Is it enough to bother you? i.e. vibration felt on the steering wheel/seats.
Or is it not supposed to idle at all? I just suddenly felt this may be an issue but i've only got 14,000 Kilometres on my 2005 Base Automatic. Hmm...
2005 Phantom Base FWD - B Package
frankl is offline   Reply With Quote
Old 08-24-2006, 11:15 PM   #2 (permalink)
View chester08's Photo Gallery
tire feathering could be causing the vibarations - new struts and shocks replacement can be the remedy. Recently I also noticed a shudder even I was just carefully travelling at 55mph, probably not the drivetrain but the engine that's causing it.
chester08 is offline   Reply With Quote
Old 08-25-2006, 12:29 AM   #3 (permalink)
Thanks Chester but my idling issue is when I'm stopped, not while cruising
Old 08-25-2006, 07:14 PM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Have a peak at your engine mounts.
Their maybe all cracket up, or seized.
Frank@toronto is offline   Reply With Quote
Old 09-04-2006, 11:48 PM   #5 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
check your MAF - probably needs to be cleaned - I had the same problem - finally cleaned and the rough idle went away - car feels as smooth as when I 1st bought it.
XR2003 is offline   Reply With Quote
Old 09-05-2006, 12:05 AM   #6 (permalink)
yelowroketman
unklekraker's Avatar
View unklekraker's Photo Gallery
what's MAF
unklekraker is offline   Reply With Quote
Old 09-05-2006, 01:55 PM   #7 (permalink)
Keep 'em Running!!
View stevenspc's Photo Gallery
Canada
MAF - Mass Air Flow Sensor. Here's a link to a PDF file that has a pretty good explanation of what it is and how it works. I've seen this type of issue before with other vehicles I've had and like the other post after cleaning the MAF the problem went away.
http://www.autoshop101.com/forms/h34...AF%20sensor%22
Hope this helps! Good Luck.
stevenspc is offline   Reply With Quote
Old 09-05-2006, 11:29 PM   #8 (permalink)
XR2003's Avatar
after cleaning the MAF you should feel a more responsive throttle & better gas mileage - not a lot but a little helps.
Hope this solves your idling problem @ the stop light.
Old 09-05-2006, 11:32 PM   #9 (permalink)
yelowroketman
question...been reading the link that steve posted but doesn't say how to clean the MAF. HOw do you clean the MAF for the 04' Matrix? I'm having the same problem too....
Old 09-05-2006, 11:42 PM   #10 (permalink)
XR2003's Avatar
try this http://matrixowners.com/forums/-t27838.html
read the top of page 1 - there are pictures
& read the top of page 4 - there is a 9 step porcess - explained in simple terms.
this should answer your questions about how to clean the MAF.
Old 09-06-2006, 12:19 AM   #11 (permalink)
yelowroketman
hey XR2003, thnxs dude...preciate the research you did for me, I will try it out tomorrow but I think i will buy the MAF cleaner @ auto zone, if there's any, if not, I will use the brake cleaner w/ spray...will keep you posted!
Old 09-06-2006, 12:23 AM   #12 (permalink)
XR2003's Avatar
ur welcome - a little warning though do not use the brake cleaner - may make the plastic parts brittle over time.
if there is no MAF cleaner @ autozone - use the electronic parts cleaner. same company crc - just make SURE that it does NOT leave any residue and that it is quick drying.
I learned this info. and more @ http://www.matrixowners.com/ - some of the people in here are long time members there.
please check it out & make some new friends.
Old 09-06-2006, 01:17 AM   #13 (permalink)
yelowroketman
dude, i just use the brake cleaner...aarrgghhhh! got too excited and didn't wait till tomorrow to clean it ! will it hurt if i only use it one time????
well, i did take it out and compare it to the picture (the wonder of wireless internet..hehehehe) and they are the same, dirty and after cleaning it, it was same color w/c is amber...test drove it and viola....idling is gone @ stop light and it doesn't get jumpy when i step on the gas pedal.....thank you XR2003, mucho apreciado
Old 09-07-2006, 12:41 AM   #14 (permalink)
XR2003's Avatar
your welcome - one time use of the brake cleaner is fine - just make sure that after about $10k miles - when it is time to clean the MAF again - use the MAF cleaner or electronic parts cleaner.
Idling in NZ Lynda Archived Corolla threads 0 02-26-2005 09:35 PM
idling prob blazin_azn MR2 Forum 1 12-11-2004 03:43 PM
Rav4 2001 Rough Idling xzulu RAV4 Forum 0 05-22-2004 11:04 AM
Idling problems part2 bkstylez Celica Forum 1 07-05-2003 09:10 PM
