Replacement antenna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2006, 10:41 AM   #1 (permalink)
View qreus george's Photo Gallery
Replacement antenna
Hey everyone...first post here.
Has anyone replaced their antenna. Looking to replace it with a shorter one, as the garage has limited height.
Let me know what the alternatives are...?
thx
qreus george is offline   Reply With Quote
Old 09-15-2006, 10:52 AM   #2 (permalink)
yelowroketman
unklekraker's Avatar
View unklekraker's Photo Gallery
thx
I did replace mine with a shorter one and it looks really good except the reception is gone bad (they disclose it before I bought it off e-bay), it's all good though coz' i usually listen to CD's or my MP3's
unklekraker is offline   Reply With Quote
Old 09-15-2006, 11:46 AM   #3 (permalink)
how much shorter is it? That's one of my biggest concerns, is that I'll lose FM receptivity. Still need to get FM stations. What about the scenario of cutting if shorter and then bonding the tip back on? Sounds ghetto, but I've seen this done and with good results.
What do you guys think?
Old 09-15-2006, 12:51 PM   #4 (permalink)
yelowroketman
Sounds ghetto..but if it works why not! as long as you won't do a ghetto job on it
Old 09-15-2006, 01:49 PM   #5 (permalink)
Keep 'em Running!!
View stevenspc's Photo Gallery
Canada
thx
Hey, has anyone installed one of the Sharkfin Antenna's? If so how was the install/fit and more importantly the reception compared to the stock antenna?
http://www.visualgarage.com/Product_Gallery_flash.html
stevenspc is offline   Reply With Quote
Old 09-15-2006, 08:45 PM   #6 (permalink)
XRS
View mistamatrix's Photo Gallery
Most people have been replacing them with S2000 antennas. Another cheaper alternative is Suzuki Aerio's antenna.
I have an S2000 antenna.
mistamatrix is offline   Reply With Quote
Old 09-17-2006, 10:22 AM   #7 (permalink)
How much shorter is the S2000 antenna? I assume it's a direct screw-in replacement? This weekend, I tried to cut it off....actually more work than I thought. Have to bond the inner shaft and then reconnect (solder) the thin copper wire that wraps around the shaft. Probably more work than it was worth. Just have to screw it back into car and see if reception is affected. In total, I took off 8-9 inches.
edit: tried it on and it works perfectly. Even tried to tune in a station from Buffalo, with and without the antenna and the final conclusion is that it works just fine. With the "stubby" antenna, I can even get the Buffalo station, so all is good. And I managed to finish it off with a glossy finish. Small win for the DIY-er !
Old 09-17-2006, 11:45 AM   #8 (permalink)
XRS
The S2000 antenna is ~6 3/4" and needs no modification to fit.
Old 09-17-2006, 09:54 PM   #9 (permalink)
How much for this antenna? Can I easily buy it from any Honda dealership?
Old 12-20-2006, 09:03 AM   #10 (permalink)
View Clamhead's Photo Gallery
I did get the sharkfin antenna, put it on yesterday. The paint match was dead on, they did a nice job (Phantom Gray pearl).
Nothing was wrong with the original antenna, I just liked the look of this one.
I was a little concerned about reception, I have all original radio equipment, But so far I can't tell any difference, and I'm pretty picky. I was worried about alternator whine, weak signal, etc.
You unscrew the original antenna whip and use a screw to attach the lead for the fractal antenna inside the new fin.
All's well so far.
Clamhead is offline   Reply With Quote
Old 12-20-2006, 10:27 AM   #11 (permalink)
Enter the Matrix
View jnixon's Photo Gallery
Thanks for the tip, Clamhead. I was curious about those myself. Would you mind checking in after another week or so and let us know if you still think this is a good product? I want to buy one, but don't want to sacrifice reception.
jnixon is offline   Reply With Quote
Old 12-21-2006, 03:00 PM   #12 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Apart from the reception differences, the Sharkfin does look the best.
Frank@toronto is offline   Reply With Quote
Old 12-21-2006, 04:53 PM   #13 (permalink)
View matrixdude06's Photo Gallery
friend of mine got the shark fin for his trix. i was thinkin about buyin it. cuz hes got no problems w/it
matrixdude06 is offline   Reply With Quote
Old 12-22-2006, 01:31 AM   #14 (permalink)
06toyoXR
View titaniumXR's Photo Gallery
i absolutely love this antenna and they color matched it amazingly. i havent had a single problem with it. reception is the same maybe a lil better. let me know if you have any questions. i have had it for about 2 1/2 months already, and not a single problem
titaniumXR is offline   Reply With Quote
Old 12-22-2006, 10:07 AM   #15 (permalink)
I haven't noticed any degradation in reception at all. Just be sure when you get ready to do your final drop onto the roof, that you are positioned right where you want to be, because the tape is some tenacious stuff.
Very pleased so far.
Wagon power antenna replacement Beaver Camry & Solara Lounge 1 03-16-2006 02:49 PM
99 corolla antenna replacement? toyotapad Archived Corolla threads 1 01-01-2006 10:58 AM
Short fat antenna replacement ? 05 Taco Crew 2nd Generation (2005+) 2 11-26-2005 12:02 PM
01 Tundra antenna replacement? davii 1st Generation (2000–2006) 0 08-24-2004 02:32 AM
Antenna Replacement Solstice Camry & Solara Lounge 1 06-01-2004 11:25 PM
