Over torqued Drain Plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2006, 08:53 PM   #1 (permalink)
View bcsan's Photo Gallery
Okay here is the situation, I have a Toyota Matrix 2004 1zz-FE with the A246E automatic transmission. Yesterday my dad was changing oil for the Matrix; however, he drained the ATF fluid instead. So we bought some ATF fluid from Toyota and planned on refilling the missing fluid. When I was retorquing the drain plug, I didn't notice the torque wrench and over torqued the drain plug. Now the drain plug won't even come off. Any suggestions?
bcsan is offline   Reply With Quote
Old 09-19-2006, 09:11 PM   #2 (permalink)
View Toyo Tech's Photo Gallery
use a longer breaker bar or ratchet get more leverage...just don't strip it
Toyo Tech is offline   Reply With Quote
Old 09-20-2006, 05:16 AM   #3 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Sit tight until the next transmission oil change. Nothing is leaking now anyways. So why worry.
During your next transmissoin oil change, you can go for a "flush" instead. They will disconnect one of the transmission hose going to the cooler (to flush out the tranny fluid while pouring new stuff in).
No need to remove the bolt.
Frank@toronto is offline   Reply With Quote
Old 09-21-2006, 06:20 PM   #4 (permalink)
View jbay's Photo Gallery
Use a ratchet with long pipe on handle , or breaker bar. And ABSOLUTELY use a 6 point socket only . If you use a 12 point socket the head of the plug may become rounded. I have some experience because I have owned an oil change facility for 10 years now . See this all the time .
jbay is offline   Reply With Quote
Oil Filter Drain Plug timpearson26 2nd Generation (2005+) 94 08-08-2007 01:43 PM
Location of R-154 manual trans. drain plug? 87M-GTE Supra Forum 2 09-19-2005 08:46 AM
manual tranny oil drain plug location?? commutercar Archived Corolla threads 2 06-22-2005 01:28 AM
Oil Drain Plug Gasket rickmadison Camry & Solara Lounge 5 05-09-2005 11:50 PM
Engine coolant drain plug REDSOXTICKET Camry & Solara Lounge 2 05-23-2004 02:53 PM
