16" rims on Matrix XRS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2006, 11:50 AM   #1 (permalink)
View sumyun's Photo Gallery
Canada 16" rims on Matrix XRS
As mentioned in title, just wondering if a set of 16" rims with 205/45 will look bad on the Matrix. I am planning to get a Matrix soon to replace my old celica, however I just brought a set of 16" aftermarket rims and was planned to put on any replacement ride.
I know 17" will definitely be better, but tires are so expensive. Anyone has 16" on Matrix? What's your thought? Upload some pictures if you have please.
Thank you,
Sam
sumyun is offline   Reply With Quote
Old 09-19-2006, 03:24 PM   #2 (permalink)
2005 Matrix XR AWD
View Whelan's Photo Gallery
The Matrix XR like mine came with optional 16" alloys. The XRS comes with 17. Essentially they look the same but I think the XRS might be a bit lowered due to the suspension tuning. But anyways, here is what mine looks liek (lip kit and all) Aside from the wheel gap, again XR with AWD, and I am painting my calipers black very soon.
Whelan is offline   Reply With Quote
Old 09-19-2006, 03:27 PM   #3 (permalink)
Crazzyboy's Avatar
View Crazzyboy's Photo Gallery
I have the stock 16" on my matrix. Not bad looking at all, check out toyota.com if you want pics. however improvements could be made with 17's.
However, buying aftermarket 16" is just a waste of money, because it comes with them stock. with 17" being the option. It could be different in canada, so I could be wrong.
Now on to the next issue, the tires on the matrix are 205/55/16. If you put on 205/45/16 you will be putting on an overall smaller tire, which will jack up your spedometer and odometer. Basically your car will be thinking you are going faster and farther than you really are. you can screw with the odometer gearing to correct this, but is quite expensive, unless you know how to do it yourself. plus putting on smaller wheels in my opinion just looks retarded.
1990 Pick-up: K&N Filter,Flowmaster 40.(sold)
2006 Matrix XRS: K&N Short Ram, TRD Sway Bars.
Crazzyboy is offline   Reply With Quote
Old 09-19-2006, 03:33 PM   #4 (permalink)
I agreed with you Crazzyboy, that's why I want to see if any available pictures of someone is actually using the 205/45/16 setup. My problem is that I have purchased the 16" rims with tires for my 86 Celica GTS already, just few months ago. I am just thinking if I can apply the sets on the Matrix and how it looks.
Old 09-19-2006, 08:00 PM   #5 (permalink)
XRS
View mistamatrix's Photo Gallery
Not much more I could add to Crazzyboy's comment. 205/45/16's are way too small. You'll rack up extra mileage in no time.
I used to run the 16" OEM rims for winter but currently use the 16" Celica GTS rims. Used 205/55/16 in both cases...
mistamatrix is offline   Reply With Quote
Old 09-21-2006, 11:08 AM   #6 (permalink)
Ok, so it still ok to run 205/55/16 setup. It looks great on your car mistamatrix.
My set of rims are look like this
16" - 5 bolts instead of four in this picture
Any comments?
Old 09-21-2006, 12:04 PM   #7 (permalink)
XRS
How wide are those rims? Are they Rota Torque's? I was looking into those but the offset was +48.
Old 09-21-2006, 12:24 PM   #8 (permalink)
The brand is Kspeed, some Taiwan brand. I am not familiar with this brand but the rims are great.
My set has offset +38mm 5x100/114.3 which fit perfectly on my Celica. PM me if you want a contact for these rims. This guy is hanging around Toronto. I knew him from other forum.
Old 09-28-2006, 09:08 AM   #9 (permalink)
thebarber's Avatar
View thebarber's Photo Gallery
those rims should look good if you drop your trix....
thebarber is offline   Reply With Quote
Toyota Matrix, Camry Rims for Sale!! Borya Camry & Solara Lounge 1 12-28-2004 03:01 AM
Toyota Matrix XRS VS 2003 Honda CRV EX Fred Garvin 1st Generation (2003-2008) 4 05-22-2003 09:33 PM
