Tire Pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2006, 01:34 PM   #1 (permalink)
View StarMan's Photo Gallery
Tire Pressure
Got a flat on my 2005 Matrix.
Changed it, got the tire pressure indicator lite.
Hit the reset and it went out. The damn thing keeps coming on when the tires heat up.
Any suggestions?
Thanks in advance.
J.
StarMan is offline   Reply With Quote
Old 09-25-2006, 08:18 PM   #2 (permalink)
Crazzyboy's Avatar
View Crazzyboy's Photo Gallery
Sorry, Not sure about that one. Although mine went off a few days ago while on the freeway, checked my tires, and they were fine. reset it and no problems since...or before this. Pehaps its just super sensitive.
1990 Pick-up: K&N Filter,Flowmaster 40.(sold)
2006 Matrix XRS: K&N Short Ram, TRD Sway Bars.
Crazzyboy is offline   Reply With Quote
Old 09-26-2006, 07:28 AM   #3 (permalink)
View Clamhead's Photo Gallery
If you read the owners manual, there are explicit instructions on how to reset. You have to turn on the ignition, push and hold the reset button until it blinks 3 times. Then it will reset.
I didn't do this the first time mine went off, because it kept re-activating, then I read the manual.
I have had mine go off 2 times and both times I had a screw in my tire and the pressure for that tire read about 20psi. I normally run about 34 psi. The system actually worked as advertised.
Good luck...
Clamhead is offline   Reply With Quote
Old 10-01-2006, 08:06 PM   #4 (permalink)
View 06XRSnGA's Photo Gallery
Make sure all 4 tires are at the same pressure. The Matrix uses an indirect system to measure air pressure. This means if one is higher or lower than the others it will cause the light to come on. This is important to note because most tire stores do not use recommended tire pressure. They just guess what is best.
06XRSnGA is offline   Reply With Quote
Tire Pressure, How much do you have? Chazmanian 2nd Generation (2005+) 28 12-07-2006 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
Recommended Tire Pressure ? unioncorps Archived Corolla threads 4 09-12-2004 03:07 AM
