Winter Tires and Rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2006, 12:26 PM   #1 (permalink)
View MisterX's Photo Gallery
Canada Winter Tires and Rims
I'd like to know what is the smalles steel rim I can get on my '05 XRS Matrix....
I've been told by a Toyota Service Parts guy, he's never put a 15" rim on a Matrix...and that smallest rim that he has done for the Matrix is the 16"
one aftermarket place in town, says that the Corolla P195/65R15 Tire rim should fit on the Matrix.....but can anyone confirm this?
my only concern is that if I go to a 15" will the rim pass the caliper?...or should I shop around for the right rim and make sure that they fit properly....
Thx in advance
Mister X
Edit- Nevermind, I called my dealership again and re-worded the question and asked about the Corolla Steel rim.....it's compatible....
MisterX is offline   Reply With Quote
Old 10-26-2006, 01:01 PM   #2 (permalink)
View Toyo Tech's Photo Gallery
I think a corolla rim should fit but try it first before you buy it.
Toyo Tech is offline   Reply With Quote
Old 10-26-2006, 04:53 PM   #3 (permalink)
View chuckles's Photo Gallery
they fit perfectly u can use a 185/65/15 also for better traction
chuckles is offline   Reply With Quote
Old 10-26-2006, 11:05 PM   #4 (permalink)
05 Matrix TRD
View trdbryan's Photo Gallery
Canada
i have even seen matrix's leaving the factory with corolla S wheels on it. I have 195/65/15 steels for my winter tires, fits perfect
trdbryan is offline   Reply With Quote
Old 10-26-2006, 11:17 PM   #5 (permalink)
View Locomotion's Photo Gallery
15" rims will give you better traction over 16" ones? I ask because I have 16" alloys and winter's around the corner. I'm shopping for a winter set, but was going to stick with 16 inchers.
Locomotion is offline   Reply With Quote
Old 10-27-2006, 05:16 AM   #6 (permalink)
View Matrix1's Photo Gallery
I think its the middle number that they were talking about.
My 06 Matrix has 205/55/R16s and going with the 185/65/R15s would be a thinner width tire as well as a smaller diameter.......Thats how I inderstand it to be anyway
Thinking about the same thing here....winter is coming.
Just may buy new Snow tires and mount them on the stock alloys and buy new aftermarket rims in the spring for my summer tires.Basically spend half now and half in the spring.....unless I find a good deal.
John R
Matrix1 is offline   Reply With Quote
Old 10-27-2006, 03:24 PM   #7 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Many of us are running with 15" (195/65R15), including myself.
Frank@toronto is offline   Reply With Quote
Old 10-28-2006, 10:40 PM   #8 (permalink)
05 Matrix TRD
Canada
if u are going to get a new set of rims for the summer i would then just use the 16" alloys for the winter tires. The difference in width from 195 to 205 isn't going to make a huge difference in grip especially since you are buying proper winter tires, but if not cheaper and better to go down to 195/65/15
Old 10-30-2006, 05:43 AM   #9 (permalink)
xrs911
View xrs911's Photo Gallery
I have been rolling on 15" inchs rims for 3 years now with Blizzak WS-50, 205-65-R15 and it handles just fine. It gives you a .01% accuracy diffenrence on the speedometer speed which is below the manufacture recomended of 3%. In other words anything below the 3% mark is the norm according to tire manufacturers.
xrs911 is offline   Reply With Quote
Old 10-30-2006, 06:55 PM   #10 (permalink)
metfan's Avatar
View metfan's Photo Gallery
Canada
I was jsut going to ask the same question, since I'm going to buy 15'' rims and winter tires.
Does it matter if it's 185/65/15 instead of 195/65/15? And for those of you who got rims, did you buy some OEM or regular ones? I heard some people say they had some problems (sometimes) with regular ones.
''A fine beer may be judged with only one sip, but it's better to be thoroughly sure''- Czech proverb.
metfan is offline   Reply With Quote
Old 10-31-2006, 08:26 AM   #11 (permalink)
wheels from toyota fit best and cheap many universal rim the hub is is way off, and the weight of the car rest on studs, shoud rest on the hub...no so good.
the 185/65//15 and the 195/65/15 are about the same size over all.. but the 185 are cheaper, and will give better traction in the nasty stuff..but are slighty hard to come by..hope this helps.
Old 10-31-2006, 05:46 PM   #12 (permalink)
metfan's Avatar
Canada
Thanks chuckles. I'll go with the 185/65/15.
Old 10-31-2006, 06:48 PM   #13 (permalink)
XRS
View mistamatrix's Photo Gallery
195/65/15 matches the stock overall diameter closer than 185/65.
mistamatrix is offline   Reply With Quote
Old 11-02-2006, 04:58 PM   #14 (permalink)
View nwt2002's Photo Gallery
I have a 07, with 17 s so far the cheapest winter tires I found are around $1000.00
should a 15 rim fit on the 07, just wondering if there is a difference between the model years.
thanks
nwt2002 is offline   Reply With Quote
Old 11-02-2006, 06:22 PM   #15 (permalink)
XRS
Zunit's Avatar
View Zunit's Photo Gallery
15" will fit all model years, there is no difference.
Gunna pickup a set of 195/65/15 and rims from CT on the weekend. They have "OE" fit wheels specifically for Matrix/Corolla that are different from the usual multi-fit ones they sell. And this week/next week the Goodyear Nordics are on sale.
The set ends up being ~$650 tax in. Good deal when compared to Michelin X-Ice for $900
Zunit is offline   Reply With Quote
FS: 17" 5-Bolt Rims w/ 225/45/17 Winter Tires Eye8Pussies Car Parts for Sale 14 10-11-2006 09:57 PM
Winter tires and rims, will 14" work on '99 LE V6? skywise Camry & Solara Lounge 4 12-04-2005 01:58 AM
17" winter tires or 16"with winter rims? watsigdunk 1st Generation (2003-2008) 8 12-18-2004 10:23 AM
