You're right, it looks great but it's pretty damn expensive.
Features / Benefits:
Designed so factory MAF sensor is calibrated to airflow. This ensures ECU will maintain proper air/fuel ratio
The system ‘s cool air intake allows a denser intake charge thus maximizing combustion potential
The longer smoother intake tubes improve cylinder fill rates maximizing power potential
All Factory EVAP VSV’s remain functional for proper emissions output
Performance Specs:
Avg. HP increase vs stock:
97.6 HP TRD vs 93.0 HP stock
Change @ peak:
9.1 HP at 7,500 RPM
Maximum change in HP vs Stock:
11.2 HP at 6,750 RPM
Avg. Torque increase vs stock:
99.3 ft.-lbs. TRD vs 94.6 ft.-lbs. stock
Change @ peak:
7.5 ft.-lbs. at 7,250 RPM
Maximum change in torque vs stock:
9.0 ft.-lbs. at 6,750 RPM
* As tested on a 2003 XRS with 6 speed manual transmission
Installation Time: 2.2 hours
Kit consists of the following: Intake tube, Filter , Hardware /mount kit
Part Number
Description
Suggested List
C0TRA-17802-01
Matrix, XRS
$510.00
C0TRA-17802-02
Matrix , XR, Base, normally aspirated (No 4WD)
$510.00
