Tpms ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2006, 07:32 PM   #1 (permalink)
View Matrix1's Photo Gallery
Tpms ?
How does it work ?
I just rotated my tires and checked the pressure and they were all
very low, Just over 24 PSI in each one.
Would have thought it would have gone off or something with them being that low.
Also my right fromt tire was cupping a little on the inside....could this be from under inflating or the alignment being off. Wouldnt think low pressure would affect one tire only.
John R
Matrix1 is offline   Reply With Quote
Old 11-06-2006, 06:52 AM   #2 (permalink)
View chuckles's Photo Gallery
the tpms on the matrix is called indirect ..it is based off the abs wheel toner ring, no sensor in the wheel.... so if three wheels are turning fast and not braking the computer will sense that the slower turning wheel has low air But if all tires when low are turning at the same rate the system will not pick it up
the better but more expensive type is the one with band attached to the wheel or the valve stem type but those every few pounds of air low the light will go on and drive you crazy.
chuckles is offline   Reply With Quote
Old 11-06-2006, 07:17 AM   #3 (permalink)
View echo7's Photo Gallery
in what year model does the TPMS became a standard accesory/option. I have a 2005 XR and i cant seem to see it on the dash when I turn on the engine.
echo7 is offline   Reply With Quote
Old 11-06-2006, 08:17 AM   #4 (permalink)
2005 Matrix XR AWD
View Whelan's Photo Gallery
Well I personally have never noticed a TPMS light go on when the car starts. I have an 05. But if you look on the left side of your dash below the dimmer you will see a button with the tire and the exclamation point with the word Reset underneath it.
Whelan is offline   Reply With Quote
Old 11-06-2006, 11:03 AM   #5 (permalink)
you mean right beside the hatch release??? I cant remember seeing that.. hmmm.. will check tonight....
Old 11-06-2006, 04:21 PM   #6 (permalink)
my 2005 XR doesnthave TPMS.. i dont see the tire button below the dimmer... I thought the TPMS was standard to the 2005XR model..
Old 11-07-2006, 05:38 AM   #7 (permalink)
Thanks Chuckles, that makes sense.....
When I did the Tire Rotation I was looking for anything that would have been some sort of sensor,
And I could figure it out.
JR
Old 11-07-2006, 08:20 AM   #8 (permalink)
2005 Matrix XR AWD
Check out my picture below of my car. I have a nice little green arrow pointing towards it. Your correct, it is right near the hatch release so
Hatch---VIP Security (if equipped)---TPMS Reset Button.
It is my understanding that it would not be checked upon startup with a light, because it is a passive system, not an active. ABS is active and so are some other things because they are constantly on. But TPMS is triggered so it only activates when needed. And it runs based on the ABS system, not like an Acura where each wheel has a sensor, therefore you can actually see the pressure from each wheel displayed.
Old 11-07-2006, 09:09 AM   #9 (permalink)
thanks whelan,, I did check and confirmed that I dont have the TPMS.. I also learned that its a standard feature for the XR AWD and not XR .
Old 11-07-2006, 11:49 AM   #10 (permalink)
2005 Matrix XR AWD
That would explain why I have it then. I bought it CPO and the guy apparently checked every box. Here is a closeup of that
Old 11-08-2006, 12:56 AM   #11 (permalink)
View trxr's Photo Gallery
Look at the power mirror switch. If you see a button labeled with the symbol: ( ! ) then you have it. Or you can set the key to the on postion. The symbol should come up in this color: ( ! )
trxr is offline   Reply With Quote
Old 11-08-2006, 12:57 AM   #12 (permalink)
You dont have traction control.
Old 11-09-2006, 10:10 AM   #13 (permalink)
2005 Matrix XR AWD
why would I, its AWD
Old 11-09-2006, 10:48 AM   #14 (permalink)
2006 MATRIX XR
Auto's Avatar
View Auto's Photo Gallery
how do you know that he doesn't have traction control? I'm wondering because thats what panel looks like in the picture. So I don't have traction control either? and I have a '06 xr.
should the traction control be on that panel where the picture is taken? if so, what does it look like?
AUT
Auto is offline   Reply With Quote
Old 11-09-2006, 11:03 AM   #15 (permalink)
i think the VSC (traction control ) should be on the 4th slot.. in whelans case the 4th slot is like a coin holder .. in my case the coin holder is where whelans TPMS is..and the 4th slot is blank...
well, its less thing to worry about...
Tpms littletaco 2nd Generation (2005+) 1 10-21-2006 09:21 PM
TPMS Malfunction? mhadden 2nd Generation (2005+) 6 10-16-2006 09:49 PM
Ivan Stewarts and TPMS screeber 2nd Generation (2005+) 4 09-09-2006 10:24 PM
06 Tpms ncpaladin 2nd Generation (2005+) 3 08-11-2006 02:49 PM
TPMS and '04 Highlander 2WD erok72 1st Generation (2001–2007) 1 03-18-2006 02:35 PM
