Originally Posted by wantin150
Look on the AWD Propeller Shaft doc I posted. Now look at the upper right hand side and you will see "73.5 (749, 54)" below the far right side of the drive shaft. The "54" is the tq in ft/lbs. Those are the 4 bolts that need to be addressed.
OK, now I don't feel so stupid ;-)))
In the Toyota Scheduled Maintenance and Service Guide it says:
"Tighten drive shaft bolt"
- and that's it.
When I cross reference the bolts you describe from the component diagram to the torque spec listing, we now find that the actual name for the bolts (yes, "bolts", not "bolt") is:
"Propeller w/center bearing shaft assy x Differential carrier assy rear"
It makes perfect sense to make sure those (four bolts) are tight, but the leap from "drive shaft bolt" to "Propeller w/center bearing shaft assy x Differential carrier assy rear" is not exactly intuitive.
Had to cut through some pretty thick fog to figure that one out ;-))))
Thanks, wantin150, for your help and patience!
