matrix trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2007, 05:47 PM   #1 (permalink)
View markl9999's Photo Gallery
matrix trouble
my 2003 toyota matrix , when starting, makes a strange kind of fluttering sound from the engine compartment, then turns over slowly as if the battery was nearly out then starts up and runs fine. it does it when sat for a while, hour or 2 not minutes. any ideas? the battery indicator on the actual battery is green- for ok and no warning lights are on.
markl9999 is offline   Reply With Quote
Old 01-17-2007, 07:22 PM   #2 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Engine Turn over slowly = weak battery...
Battery indicator changes color when it's dead...
Turn your light on, have someone look at them and then start your car. If they are very low in brightness (during starts), then its your battery.
Frank@toronto is offline   Reply With Quote
Old 01-23-2007, 01:44 AM   #3 (permalink)
View monkeyracing's Photo Gallery
I wouldn't trust one of those battery indicators. Hook a multimeter up to it to see what the voltage is with the engine off. Then do the same test with the engine running.
If it's low (below 12v) while the car's off, your battery's had it. If the voltage reads below 14v while running, then your alternator's the culprit, and not charging the battery.
Lights will dim a bit while starting, no matter what. Starting takes a lot of power.
monkeyracing is offline   Reply With Quote
Canadian matrix owners, help me price out Matrix!! darthma 1st Generation (2003-2008) 2 06-26-2005 12:40 PM
05 vibe vs. 05 matrix? northcoast 1st Generation (2003-2008) 5 03-29-2004 07:42 PM
matrix and matrix corolla??? turkf26 1st Generation (2003-2008) 2 03-11-2004 10:53 PM
Toyota Matrix XRS VS 2003 Honda CRV EX Fred Garvin 1st Generation (2003-2008) 4 05-22-2003 09:33 PM
The Matrix Reloaded Discussion (Spoiler alert) Warped Off Topic 25 05-20-2003 07:35 PM
