87 Octane in an XRS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2007, 04:42 AM   #1 (permalink)
Boost Is On The Way
View ChewDogg's Photo Gallery
87 Octane in an XRS
My dad was trying to be nice by filling up my gas tank last night. The only problem is he put Regular 87 ocatane in it. Im worried. Is it safe to drive? i put a bottle of actane booster in and I havent driven past 4k RPM.
1995 Camry XLE
www.teamphatrides.com
ChewDogg is offline   Reply With Quote
Old 02-01-2007, 05:18 AM   #2 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Yes it is...but don't go into lift too much...
Frank@toronto is offline   Reply With Quote
Old 02-06-2007, 05:37 PM   #3 (permalink)
View Mooch's Photo Gallery
What do you usually put in it?
I had a car years ago in which I used 93 octane and it cost me hundreds and hundreds of dollars to try and find out what waswrong with it. I was told the 93 octane had clouded up my spark plugs and filled them with deposits. They were a mess. When I sent one back to Aamco who I bought the gas from, they said "I''ve never seen anything like this before."
Mooch is offline   Reply With Quote
Old 02-06-2007, 05:57 PM   #4 (permalink)
Moderator
Gameroom cash: $571037
View silver04rollas's Photo Gallery
Simply because 2ZZ-GE has a compression ratio of 11:5:1 and the user manual (and fuel lid) says "use octane 91 or higher".
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is online now   Reply With Quote
Old 02-07-2007, 08:11 AM   #5 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
The manual recommends 91 or higher, as was stated. A brief use of 87 or 89 won't hurt anything. The ECU (knock sensors) adjusts for the lower octane. It isn't recommended to continue to run the 87 as this will affect performance and fuel mileage. You're safe.
2003 XRS - Indigo Ink Pearl
K&N Typhoon SR
Magnaflow Cat back Exhaust
Energy Suspension Motor Mounts
Speed Source Cable / Shifter Base Bushings
wantin150 is offline   Reply With Quote
87 or 89 Octane 2AZ FE age old question JComerford 1st & 2nd Generation (1983–1986 & 1987-1991) 6 10-07-2005 12:36 PM
2005 XRS...Safe to put in 87 Octane? otamywy Archived Corolla threads 14 03-14-2005 06:44 PM
From Octane 91 to Octane 94 on XRS silver04rollas Archived Corolla threads 26 02-23-2005 10:01 AM
home grown octane booster? Yodapower69 Hardcore Tech and Competition 0 09-17-2002 10:38 PM
