slipping clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2007, 04:12 PM   #1 (permalink)
View ionshards's Photo Gallery
slipping clutch
Hi, I'm new.
I have a 03 standard base with 40k. The clutch has started to slip and I'm wondering, so I can put together how much it will cost to fix, whether the Matrix clutch is hydrolic or cable actuated. and if it can be adjusted or if I need a new clutch ?
Thanks a lot!
Jasper
ionshards is offline   Reply With Quote
Old 03-26-2007, 08:36 PM   #2 (permalink)
XRS
View mistamatrix's Photo Gallery
Hydraulic.
mistamatrix is offline   Reply With Quote
Old 03-26-2007, 10:16 PM   #3 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
check hydro fluid level in the clutch cylinder. located next to the brake master cylinder. if low top off, also try bleeding the line to add more pressure to the clutch.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-05-2007, 06:08 PM   #4 (permalink)
The clutch has gotten to the point where it won't engage at all, so it needs to be replaced. I called the two shops around me and was quoted right around $1000 for parts and labor. 8-9 hours labor requiring the transmission and engine to be dropped. One shop said that they would replace the friction disk, pressure plate, and if needed, the main seal, and flywheel. Another shop said they would replace the friction disk, pressure plate, main seal and machine the flywheel, if it's one piece and if it was a two-piece it would need to be replaced.
Does this seem legit? or am I being hosed?
The first shop added around $200 to replace the flywheel and main seal if it was necessary, and the other shop said $1000 with machining the flywheel. And they said a new flywheel would be $300+.
Does the flywheel, necessarily, need to be replaced/machined if the clutch is slipping?
Thanks a lot for any help, I'm not really familiar with this stuff.
Old 04-06-2007, 06:26 AM   #5 (permalink)
View chuckles's Photo Gallery
about the fly wheel no one knows what the condition will be like untill they drop the tranny.
hots spots can be machined out, deep groves on the fly wheel well must be replaced.
but on hyraulic clutches their really is no adjustment for free play, machining is a cheap way out, but if your looking for the best job replacement is the answer.
chuckles is offline   Reply With Quote
Old 09-13-2007, 03:07 PM   #6 (permalink)
View Matrix Monster's Photo Gallery
does coastin in neutral before coming to a total stop, mess up your clutch? just wondering I drove a Nissan pkup 5spd for 8 years with no problem and I would always coast to a complete stop in Neutral, nevr had any clutch problem.. would doing the same thing to my XRS have any effect??? just wanted to ask... thanks
Matrix Monster is offline   Reply With Quote
clutch slipping after clutch master cyl + slave cyl replacement? msingletary Pre-88 Toyota Pickup/Hilux 3 03-15-2006 02:01 AM
Unusual Clutch Slipping Experience Kdx220 1st Generation (1995.5–2004) 0 01-17-2006 09:10 AM
Clutch Slipping aupullma Archived Corolla threads 0 10-19-2005 11:08 AM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
Clutch Slipping Keep Camry & Solara Lounge 7 07-15-2005 07:53 AM
