MAINT REQD light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2007, 12:22 PM   #1 (permalink)
Enter the Matrix
View jnixon's Photo Gallery
MAINT REQD light
Hi all. Over the weekend I noticed a light came on in my '06 Matrix XR stating "MAINT REQD". I looked up the warning light in the manual that came with the car, and it says that is an indicator that my oil needs to be changed and the light should be reset by holding the odometer reset button before starting up the car.
Now, I just had the oil changed 3 weeks ago, so I am not sure why it would need to be changed again so soon. Also, I followed the instructions in the book to reset the warning light, but it's not working. It says to turn the key to the Acc. position, hold the odometer reset button, and then start up the car. However, the light never turns off. Anybody have any ideas?? Thanks.
jnixon is offline   Reply With Quote
Old 04-02-2007, 08:15 PM   #2 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Did you do it this way:
1. Turn the ignition key to the "ACC" or "LOCK" position with the odometer reading showing. (not trip A or trip B)
2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
The odometer will display 000000 then some dashes, the light will go off once your odometer shows this.
In the manual on page 115 of the 05 matrix xr
Frank@toronto is offline   Reply With Quote
Old 04-03-2007, 08:59 AM   #3 (permalink)
Owner of an '05 Matrix XR
coquelicot's Avatar
View coquelicot's Photo Gallery
It's possible that the place that changed your oil didn't reset the "maintenance required" indicator, so that could be why it's coming on now. That's happened to me before.
coquelicot is offline   Reply With Quote
Old 04-09-2007, 01:52 PM   #4 (permalink)
Enter the Matrix
Hi guys. I followed your instructions (also found the instructions in my manual), but it does not appear to be resetting the MAINT REQD light. The manual says that the odometer should blink or something when I turn on the car and hold that reset button, but I never see the odometer change at all. When I let go of the button, it goes from the odometer to the TRIP A meter. Weird. Any other advice? Thanks!
Old 04-16-2007, 02:38 PM   #5 (permalink)
Enter the Matrix
Anyone? Bueller?
Old 05-14-2007, 05:42 PM   #6 (permalink)
View Mooch's Photo Gallery
Try this thread. It worked like a charm for me...
http://www.toyotanation.com/forum/t59350.html
Mooch is offline   Reply With Quote
Maintenance Req'd Light sandydubya Camry Hybrid 5 01-30-2007 06:56 AM
maint req light ToyotaMan1281 General Discussion 4 05-15-2006 01:16 PM
Maint. Req'd Light DaleClough 2nd Generation (2005+) 6 09-23-2005 09:46 PM
turn maint light off airskeeter 2nd Generation (2000-2004) 3 08-26-2005 12:40 PM
04 Highlander - Maint. Req. warning light bogart126 1st Generation (2001–2007) 1 11-05-2004 01:04 PM
