startup idle speed??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2007, 08:23 PM   #1 (permalink)
View kevintomb's Photo Gallery
I have an 03 matrix regular engine and automatic...my question...when I start it it IDLES VERY FAST!! it runs at like 2k for about 10 seconds,,,then at 1.6k for the first 3-4 minutes before SLOWLY slowing down to about 700 RPM after about 6 minutes...is this normal for the matrix...ive never driven another before, and it seems kinda annoying
kevintomb is offline   Reply With Quote
Old 09-16-2007, 10:08 PM   #2 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
Yup, perfectly normal.
TRXR4KDS is offline   Reply With Quote
Old 09-17-2007, 08:58 AM   #3 (permalink)
View chuckles's Photo Gallery
it all depends on air temperature..as out side air gets cool the engne will do that to help warm up.... but i agree sounds normal. must be getting cool out in Pittsburg
chuckles is offline   Reply With Quote
Old 09-17-2007, 09:18 AM   #4 (permalink)
no its not cool here, it did it all summer.......my camry DOESNT do that it runs fast for about 30 seconds then slows to a very reasonable speed
Old 09-17-2007, 09:42 AM   #5 (permalink)
2005 Matrix XRS
View D Rock's Photo Gallery
My XRS does pretty similar to that too. From what I have found, Toyota likes to set up their cars to do that.
D Rock is offline   Reply With Quote
Old 09-17-2007, 07:07 PM   #6 (permalink)
View sirmaenum's Photo Gallery
i have an '07 matrix, base model, auto.
I live in southern california (never gets cold)
i don't time it, but it usually goes to about 1.8......then slowly back down.
so i usually warm up the car about 1 min before i start taking it out.
but it's fine, i guess.
my only has a bit over 1.8k miles on it.
sirmaenum is offline   Reply With Quote
Old 09-18-2007, 10:57 AM   #7 (permalink)
View echo7's Photo Gallery
i never idle my matrix that long,, minute or less is good then roll,, and i dont pass 2k until temp is halfway..
echo7 is offline   Reply With Quote
Old 11-06-2007, 01:45 PM   #8 (permalink)
View sl1322's Photo Gallery
European Union
Hi! I'm from BELARUS, using Matrix for 3 month, and i have a problem wiht my idle speed. When the engine is hot, sometimes, for few seconds engine speed increas to 1100RPM and after that slow to normal speed 800RPM. Please, help me find a reason.
sl1322 is offline   Reply With Quote
Old 11-06-2007, 07:09 PM   #9 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
are you running auxiliary things, such as the fan, air conditioning or things like that when it revs up? it could be that it revs up that little bit briefly to accommodate the extra draw from those things on the motor. also it could be that something is using extra power (electricity) and so the alternator has to get a little more from the motor, so it revs the motor. it could also be the engine cooling fans needing power, just like the accessories listed above, and it thus revs for those.
on the other hand, it could be an exhaust leak, so it will bounce back and forth on the revving, where it will go high, then drop back down with about 2-3 seconds on each one.
how often does it rev up, and how long does the higher rev last for? do you hear any other noises when it revs up, and if so, can you describe them here?
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
Old 11-08-2007, 12:24 PM   #10 (permalink)
This higher rev not depends from my aux units. it's may be twice per 1 minute or only 3 times per day, and it's last not more then 1 second, and i never hear any noises only sound of ventilator for 1-2 sec.
Does your engine make this sound when cold? montreal 9th Generation (2003-2008) 69 05-05-2009 08:10 PM
startup idle speed?!?!?!?! MattSWE Camry & Solara Lounge 12 04-16-2006 01:45 AM
Idle Speed valve - what is it and how does it work? pschultz Camry & Solara Lounge 1 08-27-2005 02:57 PM
idle speed adjustment on 20V ST badtoy Archived Corolla threads 6 01-18-2005 10:58 AM
idle speed allmine97 Camry & Solara Lounge 3 12-28-2002 06:32 PM
