Battery empty, 2003 Mtrix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2007, 02:04 PM   #1 (permalink)
fallschirm's Avatar
View fallschirm's Photo Gallery
happen the 3th time, when (my wife ) adjusted the mirror and hit the little dip switch and put the map light an. after 2 days the battery is empty !
The light dos not get off when you take the key out of the ignition.
Any suggestions ?
Thanks
Have a great day
2003 Toyota Matrix XR
2001 Toyota Echo
1970 Lotus Europa
fallschirm is offline   Reply With Quote
Old 09-23-2007, 05:25 PM   #2 (permalink)
wonger's Avatar
View wonger's Photo Gallery
leaving any lights on will kill your battery.. if the map light is turn on and not set to door.. the light will stay on till the battery dies
88 4Runner
wonger is offline   Reply With Quote
Old 09-24-2007, 09:00 AM   #3 (permalink)
RGB
View RGB's Photo Gallery
Do you use the map lights? The easiest solution, besides asking your wife to be careful, would be to disable the map lights.
RGB is offline   Reply With Quote
Old 09-24-2007, 10:28 AM   #4 (permalink)
fallschirm's Avatar
Yes I was thinking to take the bulbs out, do you know , can I disconnected in the fuse box ?
Have a great day
2001 Toyota Echo
1970 Lotus Europa
Old 09-24-2007, 11:06 AM   #5 (permalink)
RGB
I would assume that the map lights wouldn't have their own fuse. If that was the case the fuse box would be big enough to fill up the back seat (just kidding). The easiest thing is probably just take the bulbs out. I would assume that the owner's manual probably says how to do it.
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 10:37 PM
2003 tRUNDRA BATTERY DRAIN Thurmont Introduce Yourself Here 2 02-11-2006 07:35 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
