HID relay kit for 06 matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2007, 06:07 PM   #1 (permalink)
jd's Matrix's Avatar
View jd's Matrix's Photo Gallery
Hi Everyone!!! I just bought an HID Kit for my 2006 Matrix. Does anybody know what kind of relay kit I need and where I could get it?
Your help is much appreciated. Thanx!!!
jd's Matrix is offline   Reply With Quote
Old 09-26-2007, 06:40 PM   #2 (permalink)
View notmytrix's Photo Gallery
Explain relay kit.
notmytrix is offline   Reply With Quote
Old 09-26-2007, 06:54 PM   #3 (permalink)
06toyoXR
View titaniumXR's Photo Gallery
if its an hid kit you dont need a relay for it, all you should have is a balast and a bulb and thats it
DC Strut Bar, Hotchkis Front and Rear Sway Bar, Tein Htech Springs, HID Conversion, HID Foglight Swap, Yellow Foglights,OBX Radiator Hose, Hella Supertone, Wagon Mafia Decals,Shark Fin Antenna, F5 Fujita CAI, TWM SS, 17in Scion Wheels, 225 45 17 Hankook Ventus V4
titaniumXR is offline   Reply With Quote
Old 09-26-2007, 08:33 PM   #4 (permalink)
Thanx Guys!! But I'm still kind of confused I read in a different post, that u must disable DRL'S in order for the HID's to work properly. I have a friend that installed an HID kit on a Mazda 3, and he used a relay kit.
If anybody could help me, I'd would really appreciate it!!
Old 09-26-2007, 08:51 PM   #5 (permalink)
XRS
View mistamatrix's Photo Gallery
Yes, you should disable the DRL's and that's it. If you don't disable the DRL's, your HID's will flicker like a strobe light because DRL's do not operate on full power (only 80% or something like that).
mistamatrix is offline   Reply With Quote
Old 09-27-2007, 10:30 PM   #6 (permalink)
Thanx Mistamatrix!!! This is gonna be an adventure!!!
Old 09-29-2007, 02:28 AM   #7 (permalink)
BANNED
View w203's Photo Gallery
Such a relay that is compatible with DRL exist.
w203 is offline   Reply With Quote
Old 09-29-2007, 11:23 AM   #8 (permalink)
What relay would be compatible with DRL's? And where could I get it?
Old 09-30-2007, 01:47 AM   #9 (permalink)
BANNED
Check your PM.
Old 10-17-2007, 01:41 PM   #10 (permalink)
View yota-tech's Photo Gallery
Cool
Here's how to disable DRL
http://www.kusoz.com/forums/kusoz-hi...le-switch.html
yota-tech is offline   Reply With Quote
Old 10-17-2007, 05:07 PM   #11 (permalink)
The Greatest
View CamNub's Photo Gallery
Relays connect to your battery and give the HIDs an extra power source.
CamNub is offline   Reply With Quote
Old 10-17-2007, 07:51 PM   #12 (permalink)
Stock harness is enough. Any brighter and you'd be a UFO.
Old 10-17-2007, 08:37 PM   #13 (permalink)
Thanx Once again Guys!! I found out what i needed. I finally picked up the relay i needed, now my drl's should work fine.
Thanx for all the help!!!
Old 10-18-2007, 11:40 AM   #14 (permalink)
The Greatest
It doesn't make it brighter.
Old 01-01-2008, 09:24 PM   #15 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
The relay and heavier duty harness prevents the OEM harnesses from frying as well as risking blown fuses. HID's on startup will draw upwards of 14 amps, so a 10 amp fuse (OEM) might not stand up, nor the OEM harnesses. I haven't upgraded yet. Have others had any problems with either blown fuses or fried wires? I've only had my HUD's on once since I installed them the other day. I also have my DRL's converted to the fog lights.
TRXR4KDS is offline   Reply With Quote
xenondepot no longer sells H11 4300k HID kit, where else should I get it from? germandebbie 5th & 6th Generation (2002-2006 & 2007-2011) 29 07-13-2007 02:21 PM
Xtreme HID Conversion Kit geoff5093 General Discussion 20 05-31-2007 08:16 AM
installed HID (conversion kit) EndLess82 5th & 6th Generation (2002-2006 & 2007-2011) 16 12-12-2006 04:08 PM
Navigation In My Matrix, I Need A Dash Kit BluMatrix36 Audio, Video, and Security - Tech 2 08-26-2006 12:08 PM
HID Kit: possible group-buy Tubbyc Camry & Solara Lounge 31 08-01-2002 03:19 PM
