Best Amp Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2007, 04:44 PM   #1 (permalink)
Jelias's Avatar
View Jelias's Photo Gallery
Best Amp Location
Hi. I am looking for suggestions on the best place to install an amp in the Matrix so that it is out of the way. Any ideas would be appreciated.
Thanks
Jelias is offline   Reply With Quote
Old 10-02-2007, 06:14 PM   #2 (permalink)
Toyota Nation User
4runnerracer's Avatar
View 4runnerracer's Photo Gallery
You can put it under the seat. It's a good hiding spot, especially if you have an expensive amp so it won't get stolen. However check the dimensions below the seat and the amp if you can fit it under there and at least have a 1" clearance on the top for ventilation.
01 Toyota Tundra Mods: Throttle Body coolant bypass - Differential breather extended - DRL disabled
4runnerracer is offline   Reply With Quote
Old 10-03-2007, 11:13 PM   #3 (permalink)
View notmytrix's Photo Gallery
I've had my amp under the front passenger side seat since installation. Well, okay I had it under the drivers side for like a month before I moved it. It's hidden well enough not to be seen from the outside and easily removable if I ever have to remove it.
notmytrix is offline   Reply With Quote
Old 10-08-2007, 12:11 PM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Under both seat ...
Frank@toronto is offline   Reply With Quote
Old 10-09-2007, 10:18 PM   #5 (permalink)
yotatrix's Avatar
View yotatrix's Photo Gallery
under seat is pretty tough depending on size of amp, I couldn't so it's attached to the sub box for now.
2003 Toyota Matrix XRS
2010 Toyota Corolla S
yotatrix is offline   Reply With Quote
factory amp location suprPHREAK Audio, Video, and Security - Tech 7 08-19-2006 10:11 AM
Amp Wire Route Location to rear trunk.... avalonhyper 1st Generation (1995-1999) 1 03-09-2006 03:52 PM
Amp Fuse Location WhiteRabbit Audio, Video, and Security - Tech 14 03-05-2005 03:11 AM
JBL Amp Location on 2005 Corolla? Sonnie Audio, Video, and Security - Tech 6 12-14-2004 02:59 PM
Interal Amp Location KaGe893 Audio, Video, and Security - Tech 4 05-24-2003 02:07 PM
