Originally Posted by Mark06
I'm just trying to change a burned-out bulb. Do I need to go through all this just to change a bulb? Apologies in advance for the lazy noob question.
No............... I changed the drivers side bulb in my matrix.... I think there is info on the owners manual about it.........I removed the battery( you might as well clean the terminals off while you are at it) for more room.......then removed the elctrical connection......then you unsnap the metal wire thingy and you can twist and slide the bulb out from around the rubber gasket thingy....it's a good idea to put the dielctric? grease on the electrical connection
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
