Tire Problem! Flats All The Time! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2007, 07:47 PM   #1 (permalink)
View MatrixLady's Photo Gallery
I'll give you some background on my beastie. It's an automatic Matrix, 2005 model. just rolled 40 thousand kilometres, (25,000 miles). Its on its second set of tires. I keep getting flat tires from it, especially in the winter. Our mechanic, who I trust implicitly, said it's oxidation from the aluminum rims. Has anybody else had this? It's not an enjoyable problem when you live through Canadian winters!
MatrixLady is offline   Reply With Quote
Old 11-20-2007, 08:28 PM   #2 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
sounds to me like your rims are bad. oxidizing is just a fancy term for rusting. aluminum when it oxidizes becomes much like a powder and will very easily come away, which can leave gaps, and it sounds like this may be the case for you. my only suggestion would be to replace the rims, or if you have a service agreement you bought from the dealership, go in complaining very loudly and very much until they replace the rims.
even aluminum rims should not be crapping out on you after such a short time.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
Old 11-20-2007, 09:31 PM   #3 (permalink)
View notmytrix's Photo Gallery
Switch to steel rims in the winter time with winter tires.
notmytrix is offline   Reply With Quote
Old 11-20-2007, 09:56 PM   #4 (permalink)
06toyoXR
View titaniumXR's Photo Gallery
i have 16 in steel rims fro sale 100 plus shipping, practically brand new, used for 2000 miles in florida.
DC Strut Bar, Hotchkis Front and Rear Sway Bar, Tein Htech Springs, HID Conversion, HID Foglight Swap, Yellow Foglights,OBX Radiator Hose, Hella Supertone, Wagon Mafia Decals,Shark Fin Antenna, F5 Fujita CAI, TWM SS, 17in Scion Wheels, 225 45 17 Hankook Ventus V4
titaniumXR is offline   Reply With Quote
Old 11-20-2007, 10:04 PM   #5 (permalink)
titaniumxr -- I can only imagine the shipping costs from Florida, but thanks! I also believe I have 17 inch rims. I'd have to check my specs. I lease this vehicle and am planning on selling it when in 18 months when it becomes due to payout. Leasing--bad idea! That's why I don't want to put too much more money into it -- I won't get any of it back.
Old 11-28-2007, 06:02 PM   #6 (permalink)
GeorgeNfla
Georgenfla's Avatar
View Georgenfla's Photo Gallery
I would take those rims/tires off the car and submerge them in a water tank individually to see where the air is leaking. If its from the middle of the rim, I would head to the dealer, and say "What the F*%$@ ? This thing is under warranty!"
Georgenfla is offline   Reply With Quote
Old 11-28-2007, 07:49 PM   #7 (permalink)
View toyomoho's Photo Gallery
Most likely the bead area where the tire meets the rim has the corrosion. You will need to have the tire removed and if possible the corrosion removed to restore an airtight seal.
Contact a wheel, tire, body or wheel repair specialty shop that can inspect and repair the rims. Don’t use abrasives or corrosive cleaners on the rims; some owners state using nitrogen in place of air in tires helps reduce corrosion problems.
You might be getting road salt or corrosive snow/ice removal chemicals in the bead area.
Low Tire Pressure Indicator Reset FYI Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-29-2011 09:43 AM
Questions on going Pro eddie926 Detailing & Car Care 7 10-17-2007 06:37 PM
2005 Camry SE - New tire time cor 5th & 6th Generation (2002-2006 & 2007-2011) 14 10-15-2007 02:38 PM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Now this is OFF TOPIC modifierLE Off Topic 14 09-06-2005 08:49 PM
