cold air intake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 08:52 AM   #1 (permalink)
View matrixowner's Photo Gallery
cold air intake
I drive an '03 XRS. Does anyone have experience for the add-on cold air intake systems? Easy to install? Increase in horsepower. Noisier?
I see them on the TRD site for around $250.00 and also on eBay for $50.
Art
matrixowner is offline   Reply With Quote
Old 11-22-2007, 12:49 PM   #2 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
cold air intake can help you to gain around 5 hp, but you also have to have the chip reprogrammed a bit to know it has the CAI. i also have an 03 xrs and i am looking into getting a CAI as well. to install it looks pretty easy, and i am not much of the type to know what i am doing inside a car.
as for the difference between CAIs, they are all essentially the same thing and will all hook up in about the same way. it is a pipe with a filter on one end of it. it would be good to have a spot already built into it to mount on the mass air flow sensor. the trd cai has that spot, but they are also selling the TRD name with it.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
Old 11-26-2007, 05:36 PM   #3 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
I think he means the ECU needs to be reset. Make sure to unplug the negative to the battery.
2 reasons:
1) To keep the MAF safe.
2) The ECU will reset to learn the new airflow from the CAI. Most would suggest to let the car idle for 10-15 minutes before driving off.
Good luck!
XR2003 is offline   Reply With Quote
Old 11-28-2007, 08:17 PM   #4 (permalink)
thebarber's Avatar
View thebarber's Photo Gallery
cai or sri is easily the best mod you can do to start off. get a cheapy ebay short ram intake and throw a k&n cone filter on it.....youll be under 100$ and youll gain close to 10whp and 7wtq.
itll be louder, sure, but speed takes balls.
thebarber is offline   Reply With Quote
Old 12-04-2007, 09:30 PM   #5 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
I installed a TRD cai, took about a hour on my 03 base model trix. Lost some MPG's, but I can feel the differece in accelleration from stock air intake system.
mickeyd is offline   Reply With Quote
Old 08-23-2008, 07:19 PM   #6 (permalink)
View Bizon71's Photo Gallery
I installed a K&N Typhoon Short Ram on my '03 Xrs. Definitely big difference, awesome sound out of the engine and better mileage!!!!!! Do it right, don't go cheap! It could damage other components, specially with cheaper non Dyno Proven CAI Systems! Asides from it, it looks so good under the hood!
Bizon71 is offline   Reply With Quote
2003 Camry Se Intake In Pic!! rgud 5th & 6th Generation (2002-2006 & 2007-2011) 72 04-25-2007 10:03 PM
turbo abew330 Supra Forum 0 02-07-2007 05:51 PM
07 Sedan Cold Air Intake ??!!???? doodoo Yaris, Vitz and Echo Forum 0 09-25-2006 05:35 PM
Cold air intake 80 bucks. cam2Xrunner Camry & Solara Lounge 7 07-02-2004 02:50 PM
custom cold air intake for 4cyl Gen 2 phat91camryLE 1st & 2nd Generation (1983–1986 & 1987-1991) 0 09-26-2002 06:05 PM
