Anyone installed an XM Roady in a Matrix? ... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2007, 09:55 AM   #1 (permalink)
View fendertweed's Photo Gallery
Question Anyone installed an XM Roady in a Matrix? ...
I'm surprised I came up empty on a search for this ... so ...
Has anyone installed an XM Roady receiver in a Matrix? How'd you do it?
There's no cassette player (I know, still so 70s but it is a great way to get good XM signal strength to the radio). I can try to get in via their link to the antenna but that's going to require some hairy (to me) work getting under the headliner near the antenna, I think.
Has anyone done this? Thanks for any info,
Jon
fendertweed is offline   Reply With Quote
Old 12-12-2007, 12:30 AM   #2 (permalink)
View brmacdon's Photo Gallery
I installed Siruis in my 2007 Matrix (stock radio) using USA SPEC's PA12-TOY. Works great. Easy to install. If the Roadie has a line out then this solution will work.
brmacdon is offline   Reply With Quote
Old 12-12-2007, 06:12 AM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
If you're going to use the antenna module to hear xm, then you'll do it at the back of the radio where the cars antenna wire plugs in. You shouldn't have to go under the headliner at all.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-12-2007, 08:05 AM   #4 (permalink)
Thanks.... the Roadie does have a line out, can you explain to me how you routed it into your Matrix radio? I'm not sure whether or not it'll work in our '05, it has the JBL upgrade 6-disc/AM/FM, but I do want to get at it if I can.
Thanks for any info you can provide,
Jon
Old 12-12-2007, 08:11 AM   #5 (permalink)
Thanks Qslim,
Yeah, I will have to use antenna mode on the Matrix. ... I haven't used that before so my memory of how it connects is weak/nonexistent... I know they have one that goes onto the antenna itself and then wires back to the radio.
Are there instructions anywhere on TN for removing the radio to get at the antenna connection, or can you describe how to get to it? I did a search on "radio remove" or "removal" and got no hits.
Thanks,
Jon
Old 12-12-2007, 08:14 AM   #6 (permalink)
I just looked at the PA12-TOY... how hard was it/ what was involved in installing that? Do they have instructions to clarify where the various wiring loom connectors go? Any splicing, cutting, etc., necessary?
I'm not afraid to do it, just want to know what I'm getting into, LOL.
Old 12-12-2007, 08:52 AM   #7 (permalink)
Qslim's Avatar
Originally Posted by fendertweed View Post
Thanks Qslim,
Thanks,
Jon
Here's a diagram, it's real easy. Pop off the plastic trim and you'll see the bolts that hold the radio in.
-- Get him, boy....
Old 12-12-2007, 02:41 PM   #8 (permalink)
The installation is pretty straight forward. USA Spec also makes a model without the IPOD interface that has two sets of RCA jacks. You have to pull out the radio as described above. Very easy. The plugs that instrument cluster can be a bit tricky to detach so be patient.
Essentially you the USA Spec unit comes with a wiring harness that plugs directly into the back of your radio. No soldering, wire cutting, no mess. I had the JBL system in my Tundra and the unit worked fine. The unit adds and auxillary input that becomes accessible by pressing the CD key on your radio. You can switch between your CD changer and satellite radio. With the IPOD unit you can still play CDs but you should not have your IPOD hooked connected when you play CDs. This seems to cause sporadic issues. Your mileage may vary.
I have also used an FM Modulator as you are describing. Very very simple install. Again you need to pull the radio. Then all you do is plug your antenna into the modulator and plug the modulator into the antenna plug on your radio. Works well and its cheaper than the USA spec unit.
The most time consuming part of the satellite radio install is the antenna install. I installed mine on the rear of my roof (passenger side). I ran the wire out through the brake light assembly. No drilling required. I then ran the wire up the passenger side using under the rear storage area, door jams and carpet.
Old 12-15-2007, 04:10 PM   #9 (permalink)
I'm going w/ the Schosche (sp) FM modulator from Crutchfield. Looks very easy.
I have run the antenna on the 2 cars I've set up so far (73 Porsche, 01 Audi A6 wagon) from the car mount for the Roady XT under the dash, in the trim gaps and up to the dashboard top. I mount it with about a 1/2" square piece of DualLok and it gets reception fine thru the windshield, no need for the long runs back and out of the car.
We'll see how it works on the Tacoma & the Matrix.
thx,
jc
XM and Sirius expected to merge PigsEye Off Topic 13 02-19-2007 10:15 PM
toyota xm unit ctaudio 2nd Generation (2005+) 6 12-10-2006 09:47 AM
possibly getting a new matrix, but... barry sanders 1st Generation (2003-2008) 11 07-28-2003 02:37 AM
The Matrix Reloaded Discussion (Spoiler alert) Warped Off Topic 25 05-20-2003 07:35 PM
Big Matrix Meet, Irvine Toyota, Sunday 3rd of November, 10AM RAAMaudio Regional Meetings and Events 1 11-01-2002 01:22 AM
