Transmission rattle.. help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2007, 02:25 AM   #1 (permalink)
View mechael's Photo Gallery
Question Transmission rattle.. help!
Hi,
I am a new proud owner of a 2005 4WD Matrix XR. Just picked up the car today from the dealership. It is a used car with 59000 km on it. Loved the car, everything feels good until I slowly noticed a slight rumble from the transmission...
At first it felt like the car up-shifted and didn't have enough torque, but when I paid attention to it, I realized it wasn't the case. If I slowly accelerate, at around 60km/h, the rev would be at around 2200 rpm, and if I slightly release the gas pedal and maintain the speed at 60km/h, the gear would shift and it would stay at around 1900 rpm, and at that moment there was a subtle but noticeable rumble / vibration / shake in the car that you can actually hear the rumble and feel the shake at the shift knob. If I maintain the speed, the rumble would not stop, and if I press down the pedal harder to accelerate, it would down-shift and the rev would jump back to 2200 rpm, and then the shake is gone. I tried it many times and it's repeatable at the same km/h every time.
- Does anybody have had similar problem?
- What is the problem? How do I describe to the dealership? I worry that they won't honor the warranty.
Thanks so much.
mechael is offline   Reply With Quote
Old 12-17-2007, 04:45 PM   #2 (permalink)
View notmytrix's Photo Gallery
It's not a problem, as I am told, it's quite normal when you hit over 60km/h at least for the 4WD and hold speed around before 70km/h. It's not a rattle but rather feels like the engine is struggling right? You should be okay. Saves you fuel.
notmytrix is offline   Reply With Quote
Old 02-04-2011, 09:42 AM   #3 (permalink)
View naamassage's Photo Gallery
Originally Posted by mechael View Post
Hi,
Thanks so much.
Better get it checked. My 2003 toyota matrix's transmission just went out. I heard a "rattle" too and was told it was nothing to worry about.
naamassage is offline   Reply With Quote
Old 03-16-2011, 07:10 PM   #4 (permalink)
View syang1983's Photo Gallery
My 2003 AWD does it too but only at 35-40 mph. It kinda vibrate when i hold the speed at 35-40 but once i give it a little gas the vibration goes away. Still trying to find a solution. I think it has something to do with the rear differential because it seems that a lot of AWD models encounter the same problem. I am waiting until it's warm and change the rear differential fluid to see if it helps.
syang1983 is offline   Reply With Quote
Recurring Problem with 1995 Lexus ES300 Transmission mpr2 General Lexus Discussion 5 12-30-2008 08:54 PM
Transmission Problems wareagle2000 2nd Generation (2005+) 21 07-23-2007 09:11 PM
Transmission Fluid Accident LinhDuyVo 2nd Generation (2005+) 16 11-14-2006 01:28 PM
??'s about the nver needs changing AT fluid kn38ms 2nd Generation (2005+) 22 10-29-2006 07:42 PM
