HID Powering Up Problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2007, 05:58 PM   #1 (permalink)
imEric!'s Avatar
Gameroom cash: $113357
View imEric!'s Photo Gallery
Arrow HID Powering Up Problem.
OK, I just replaced my existing HID ballasts and bulbs with a new set 2 days ago. My car still has the daytime running light enabled and the HID comes on whenever the car starts.
So anyway, I noticed a very strange issue today. The HID doesn't come on when I start my car (whenever I don't have the handbrake pulled), even manually turning on the headlights will not work.
What will make the HID work is make sure the handbrake is pulled before starting the car, then start the engine (while leaving the handbrake pulled), turn on the headlight manually, then release handbrake, start driving...
I never had this problem when I was using my Prolumen HID setup...
So what do you think it's wrong?
.Eric
imEric! is offline   Reply With Quote
Old 12-22-2007, 10:36 PM   #2 (permalink)
View notmytrix's Photo Gallery
Should have disabled the DRL's. Now you're blowing bulbs and destroying the ballast. Someone else with thorough knowledge about this may help you even further. I for one disabled the DRL's beforehand and have been using the same bulbs close to 2 years now. *knocks on wood*
notmytrix is offline   Reply With Quote
Old 12-23-2007, 12:10 AM   #3 (permalink)
bc toy's Avatar
View bc toy's Photo Gallery
cut this wire.......it's not too hard
bc toy is offline   Reply With Quote
Old 12-23-2007, 08:23 AM   #4 (permalink)
imEric!'s Avatar
I cut the wire tonight and voila, my HID turns on whenever I want it to!!!!
This is kinda strange because my old HID setup worked very well even with DRL enabled...
.e
Old 12-23-2007, 05:54 PM   #5 (permalink)
The Matrix has you...
View PA Firefighter's Photo Gallery
Is cutting the wire at pin 12 the way to disable DRL on 04+ Matrices? According to http://www.lightsout.org/disable.html#Toyota you cut the yellow wire at pin 8.. Is that just for my '03?
'03 XR - Lunar Mist, AEM Short Ram Intake, Borla Catback Exhaust, Vibrant Strut Tower Brace, Tein S-Tech Springs, De-badged Hatch, TYC Black Tail Lights, LED Front Signals, LED Rear Lighting, I-Series Stubby Antenna, DRL Disable, 17" Gloss Black Falken Torque 5 wrapped in Falken Ziex Ze 912
PA Firefighter is offline   Reply With Quote
Old 12-25-2007, 01:48 AM   #6 (permalink)
Just cut the red/white wire at pin 12 in the DRL module. That should disable your DRLs completely. You can even put a switch if you wanted to.
Manual driver seat problem satamas 9th Generation (2003-2008) 0 11-05-2007 08:30 AM
2005 Echo Hatch HID install problem lvsprelude Yaris, Vitz and Echo Forum 2 10-18-2007 01:03 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
HID problem Jchan Camry & Solara Lounge 69 05-10-2006 08:39 PM
after market H4 hid kit glare problem! szu604 Camry & Solara Lounge 2 10-07-2004 07:45 PM
