Rev Problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 02:04 PM   #1 (permalink)
View Brusher's Photo Gallery
Canada Rev Problem?
Hi,
I've a 2004 Matrix XRS, and recently I've been having a problem in each gear, it seems when I push on the gas it revs high and I don't accelerate. Eventually I'll pick up speed, but it's with marginal pushing down on the gas pedal, to ensure it doesn't run away with the revs. If I really hammer down on the gas to try and accelerate it just red-lines, and the smell of burnt cluch (I'm assuming). It has 108Km on it, and suggestions would be appreciated.
Thanks
Shane
Brusher is offline   Reply With Quote
Old 01-03-2008, 03:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
Stick or auto? Does the engine rev up when you push on the pedal but the car does not accelerate?
Old 01-03-2008, 03:36 PM   #3 (permalink)
It's a stick, and yes it revs up without accelerating when I push on the gas
Old 01-03-2008, 05:26 PM   #4 (permalink)
The problem is the clutch is slipping badly. It is either worn out or not fully engaging and needs adjusting. This is why you smell some burnt clutch when you rev the engine to high; the clutch is heating up because of the friction as it slips.
Old 01-03-2008, 11:35 PM   #5 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
Normal clutch life in these cars is 100K unfortunately. The one bad part of the XRS. Weak clutches that only last 100K. Whatever you do, don't put another OEM one in. Go to www.matrixowners.com and search all about aftermarket clutches for the XRS.
TRXR4KDS is offline   Reply With Quote
Old 01-04-2008, 09:38 PM   #6 (permalink)
XRS
View mistamatrix's Photo Gallery
It does sound like your toast. Mine original clutch lasted 53000km and replaced it with an RPS Sport Series w/ Street disc. http://www.turboclutch.com/sport.html
With my driving style, I should have gone stronger because my clutch is slipping again (currently at 174000km).
I'm pretty set on getting the South Bend Clutch. http://www.dxdracingclutches.com/home.html The guys on newcelica.org are giving it good reviews and recommendations. *************.com are currently having a group buy on it at really good prices. I'll probably bite in the next few wks. http://www.*************.com/forum//...ad.php?t=67761
EDIT: lol. It's funny how matrixowners.com isn't censored but n e w c e l i c a . o r g (first censor) and 9 t h g e n c o r o l l a . c o m (2nd censor) is!
mistamatrix is offline   Reply With Quote
2002 Tacoma 4x4 TRD Differential or Transmission problem? sailingceleste 1st Generation (1995.5–2004) 15 07-26-2007 12:14 PM
Yet another problem burningthebridg Celica Forum 1 04-13-2007 03:26 PM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
