Loose belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2008, 08:54 PM   #1 (permalink)
The Matrix has you...
View PA Firefighter's Photo Gallery
Loose belt?
On colder mornings (low to mid teens), I hear a squealing from the engine. The current belt is only 18 months old. Once the engine heats up a little the noise goes away. It didn't do this last winter that I can remember. Anyone have any suggestions?
'03 XR - Lunar Mist, AEM Short Ram Intake, Borla Catback Exhaust, Vibrant Strut Tower Brace, Tein S-Tech Springs, De-badged Hatch, TYC Black Tail Lights, LED Front Signals, LED Rear Lighting, I-Series Stubby Antenna, DRL Disable, 17" Gloss Black Falken Torque 5 wrapped in Falken Ziex Ze 912
PA Firefighter is offline   Reply With Quote
Old 01-06-2008, 09:17 PM   #2 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
Serpentine belt. I've replaced mine every year so far because of the annoying squeeling. Apparently the Gatorback belts are the way to go.
TRXR4KDS is offline   Reply With Quote
Old 01-06-2008, 10:24 PM   #3 (permalink)
XRS
View mistamatrix's Photo Gallery
I had mine replaced under warranty. It still squeals but only when it's humid out.
mistamatrix is offline   Reply With Quote
Old 01-08-2008, 02:09 PM   #4 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
Since belt is still "relatively" new, check for cracks and other signs of wear.
Most likely it is the belt tensioner going bad and not "tensioning".
Another factor may be the water pump is leaking and that liquid is getting onto the belt.
Hope you find the reason and answer to this problem.
XR2003 is offline   Reply With Quote
Old 01-08-2008, 02:21 PM   #5 (permalink)
View echo7's Photo Gallery
its the serpentine belt.. i had the w pump replaced last year and new serpentine belt installed.. 2 days later the same squeel...
i thought it was only the matrix,, but I also heard a camry squeel
echo7 is offline   Reply With Quote
Old 01-08-2008, 04:07 PM   #6 (permalink)
What's the shelf life on these belts? When I bought my trix in June of 06, it started happening every time I started the car, took it to the dealer and they replaced it no questions asked. Now that my warranty is up, (and has been), what can I expect to pay for something like this?
Old 01-08-2008, 05:41 PM   #7 (permalink)
as trxr4kds said,, replace with gatorback,, this should solve your problem..
mine is still underwarranty and will replace to aftermarket when the time is up..
Old 01-08-2008, 06:34 PM   #8 (permalink)
Super deluxe Happy member
Quicksilver300's Avatar
View Quicksilver300's Photo Gallery
that's strangeyou guys have this problem with the matrix. I've a 92' camry 5sfe(127,000mi), and it only squeals if I go in a deep puddle, and even then it does for just a few seconds.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
Quicksilver300 is offline   Reply With Quote
Old 01-10-2008, 06:19 PM   #9 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
just change it dude, its easy and takes 20 mins with a helper, a 19mm wrench and a strong arm. there is a how to somewhere on the site, its pinned at the top of the forum i believe. it will take a few mins longer if you have no helper. i did mine on the side of the road in louisiana. LOL. mine went after 30,000 miles...but those are salty miles in upstate NY.
the belt is $20 at autozone, but if you go gatorback, shouldnt be more than $50, i just threw an autozone brand on for the time being, i was on the side of the interstate at the time and just wanted what they had at the next exit. when its time to replace again, i will go gatorback as well.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
for all you 02-03 owners....belt tensioner TSB (please read) CharmCityES 5th & 6th Generation (2002-2006 & 2007-2011) 8 10-22-2008 11:07 PM
accessory belt whine? DAMON Camry & Solara Lounge 12 06-27-2006 01:40 PM
