check engine light came on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 12:49 PM   #1 (permalink)
View cbinva's Photo Gallery
I have an 04 Matrix XR and the check engine light came on. I took it to Auto Zone and got two codes PO133 and PO441. Took the gas cap off and put it back on and the check engine light went off. Was wondering if that is all or if there is something else I should be looking for? Thanks.
cbinva is offline   Reply With Quote
Old 01-13-2008, 10:19 PM   #2 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
nope thats all...not sure what the codes mean, and im too lazy to look it up, but you fixed it and now all is well...carry on with your day
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
Old 01-14-2008, 07:17 PM   #3 (permalink)
Jered's Avatar
View Jered's Photo Gallery
The code PO133 is a O2Sensor Circuit Slow Response (Bank #1 Sensor #1) and as for code PO441 is an Evaporative Emission Control System Incorrect Purge Flow. Basically with most cars today if you don't tighten the fuel cap enough it with throw a CEL. So just let it click a few times when you tighten it and you should be fine. By the way are you a member of MatrixOwners.com, if not you should check it out. There's lots of good accessible information that you could use and lots of great people that can help you with any questions you may have.
2005 Matrix Xrs Phantom Gray Pearl
Eibach Sportline Lowering Springs, Yellow Tinted Fogs, Next Mod Here
www.myspace.com/jeredjones
Jered is offline   Reply With Quote
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
2005 Matrix Check Engine Light? : OBDII SCanner Buying Tips? Matreks 1st Generation (2003-2008) 13 07-05-2005 11:25 PM
