2003 std. matrix doesn't crank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2008, 10:50 AM   #1 (permalink)
View b03matrix's Photo Gallery
Hello,
I just bought 2003 Matrix standard 5 speed. The problem is when turn the key to start, the instrument panel light on but the engine doesn't crank at all (4 out of 5 times) . But when it does the engine start and run fine.
I would like to have any suggestion to fix this problem I also like to know where are the location of starter relay, clutch start switch and oxygen sensor (bank 1 sensor 1 and sensor 2).
Thank you,
b03matrix is offline   Reply With Quote
Old 02-04-2008, 03:33 PM   #2 (permalink)
View ruther's Photo Gallery
This may be obvious, but....
Is the clutch in all the way?
I just got a 2004 Matrix 5-speed and unless I have the clutch down ALL the way to the floor it will not start either.
ruther is offline   Reply With Quote
Old 02-04-2008, 08:20 PM   #3 (permalink)
XRS
View mistamatrix's Photo Gallery
^Good point. In most cases, it's simply the 'button' on the floor that isn't depressed by the clutch that doesn't allow the car to start. Make sure your floor mats are out of the way as well.
mistamatrix is offline   Reply With Quote
Old 02-04-2008, 11:54 PM   #4 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
i have heard of the clutch sensor buttons wearing out in manuals before, so what happens is that you push the clutch in and try to start but it doesnt work all the time, and you have to stomp on the thing a few times, or really seem to grind the clutch pedal into the carpeting on the floor. assuming that this is the problem, there are 3 ways to 'fix' it. Option 1: take it back to the dealer (assuming you are under warranty still) and demand that they replace it. Option 2: if you know what you are doing, replace the button yourself. Option 3: put a small jumper wire in place to short out so you never have to worry about pressing the clutch pedal in to start the car. do note though that this is a 'safety' feature, because it keeps you from starting your car while it is in gear with the clutch engaged, meaning that the motor will turn. if you want to short out the button, go look on www.matrixowners.com for instructions (actually search for it, not start a new thread, because i remember reading the instructions on that at one point)
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
Old 02-05-2008, 08:02 AM   #5 (permalink)
I did not see the clutch sensor near the pedal. I push the clutch few times to the floor then it starts. According to the manual, the starter relay maybe bad. So far, I could find it yes. I'll adjust the clutch to see if it is better or not.
Thank you all for the reply.
Old 02-05-2008, 04:26 PM   #6 (permalink)
I found the safety switch close to the floor. I bend the piece metal which contact to the switch, from the clutch pedal down (can't move the switch upward). Now the engine crank and start right away.
Thank for your help,
BN
Old 02-09-2009, 12:13 PM   #7 (permalink)
View Swabby's Photo Gallery
b03matrix - can you please post a photo of the sensor and let me know where i can hunt for this and do the same as what you did?
i am have 03xrs with this problem. my factory mat is pushed into the floor so hard that i think i will eventually have a hole on my floor. lol. i am not using any winter mat, as this may contribute to this problem even more.
thanks.
Swabby is offline   Reply With Quote
Old 02-09-2009, 01:51 PM   #8 (permalink)
Hello Swabby,
This http://matrixowners.com/?showtopic=68152 shows how to do it.
Old 02-09-2009, 03:03 PM   #9 (permalink)
Thanks b03. I will try it out this weekend. Still working fine and how long did it take you?
Old 02-10-2009, 10:51 AM   #10 (permalink)
Max. 15 minutes
Old 02-22-2009, 08:51 AM   #11 (permalink)
View anita's Photo Gallery
04 wont crank
its your starter
anita is offline   Reply With Quote
Old 02-25-2009, 09:00 AM   #12 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
or put a wire to the starter and to connect to the battery..
TRDXRS...
Corolla_reps is offline   Reply With Quote
