Replacing header w/ ceramic header? Yes or No? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2008, 11:04 AM   #1 (permalink)
View matrixslpr13's Photo Gallery
should i replace the stock header w/ a ceramic header or leave the stock on?
also, should i replace the radiator if it is stock also.
it's a 04' Matrix XR
matrixslpr13 is offline   Reply With Quote
Old 04-11-2008, 07:41 PM   #2 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
you will find better gains in replacing the header in the 1zz, which is the motor in the base & XR. it doesnt have to be ceramic, but if you do get a ceramic header, be sure to give your car about 2 minutes to warm up and cool down for when you are driving, and up to 5 minutes if it is close to or below freezing. ceramic headers can crack if you tighten the bolts on too much, or if there is too much difference between temperature of exhaust gas going through and the header itself. it is sort of like glass, and several other materials. as the temperature changes, the exact size changes, so as it gets warmer, it expands, and it contracts when it cools. the points where it connects to other pipes, or the motor, won't be an issue because it was designed to fit that.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
Old 04-21-2008, 03:57 PM   #3 (permalink)
View boi_si's Photo Gallery
make sure to have/use proper mounting brackets. exhuast systems move around causing the ceramics to crack easily.
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
