I was asking about oil myself over at
www.matrixowners.com (go sign up there, because they have a ton of help and DIY projects).
The best oil for the 2ZZ motor is going to be a 5W30 full synthetic. Many people i asked use either Mobil 1 or German Castrol (must say European formula on it).
There are 5 tiers of oil. Tier 1 doesnt even make it into cars. Tiers 2 and 3 are often referred to as Dino oil, which is your traditional oil that comes from the middle east and is pulled and refined from the ground. Tier 4 is going to be your best bang for the buck. Tier 4 is going to be most of the synthetic oil you come across. Mobil1's and Castrol's synthetic oils are in this category. These are made completely in a laboratory and don't have stuff the comes from nature. Tier 5 oils are for your hardcore motors that you are going to beat the crap out of. These are ethers. An example of tier 5 oil is Redline. As well as being the "best" there is currently, it is also the most expensive.
I have a 2003 XRS as well, with 81,000 miles (~130,000 km). I have one more free oil change from the dealer i got my car at, then i am going to use German Castrol. You can usually pick up German Castrol at Auto Zone.
2 other things to consider in changing your own oil are the oil filter, and the weight of the oil. Many people use a slightly lighter oil to get better performance from the motor. Depending on how far north you are in canada, you may want to use the 5W30 rather than go lighter. i have heard of people using 0W30 in their XRS. If you are close to the US border, i would suggest using the 0W30 if you want better performance. if you are further north where it gets colder in the winter, then stick with the 5W30. As for the filter to use, i havent figured out the "best" one yet, but many people at matrixowners.com think the stock XRS oil filter seems to do decently.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car
- Part Time Mod Thule Roof Rack
