tail lights and dash not workng and it's not fuse 18? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2008, 12:39 PM   #1 (permalink)
View xdrixn's Photo Gallery
Whle checking fuse 18 I did find two wires that seem like they should be attached somewhere but I can't find where. Can anyone help or does every matrix owner have these two wires going nowhere?
xdrixn is offline   Reply With Quote
Old 04-28-2008, 09:20 AM   #2 (permalink)
2005 Matrix XRS
View D Rock's Photo Gallery
It is entirely possible that those wires don't go to anything. They may just be for options that you don't have. Most cars have some wiring that goes no where for just that reason.
Wish I could help more.
D Rock is offline   Reply With Quote
Old 04-28-2008, 01:23 PM   #3 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
i had the same prob as well 2 yrs ago.....im pretty sure it is a fuse if i can remember it controls tails and dim light....but try checking your tail light fuse or Dome fuse...
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 04-28-2008, 05:29 PM   #4 (permalink)
it turns out it was/is the fuse. my bad. I guess I wasn't looking close enough, however it keeps blowing out when I replace it with a new one. I did replace the stereo recently? I'll have to look for wires touching I guess?
Old 05-14-2008, 10:42 PM   #5 (permalink)
08 Matrix 5speed
View ztoy08's Photo Gallery
Lightbulb
If you just installed a stereo check the Illumination Ground wire on the wiring harness you used between your head unit and the toyota wiring harness. If connected to ground then power back feeds thorough the circuit causing the fuse to blow thus causing your tail lights and accessory dash lights to go out. I had the same problem 2 months ago after installing my new alpine Head Unit.
ztoy08 is offline   Reply With Quote
