Have a fiend that JUST bought a used Trix XRS. Doe she HAVE to put Premium in it with these prices or will regular do the trick just less HP?
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
the 2ZZ-GE must run on 91 octane or higher gas. this is premium, the expensive stuff. the low octane forces the motor to retard timing, and that cuts back on power. this is not a good thing for the motor. the lower octane in the car will also cause worse gas mileage.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
I have had the gas jockies put regular in my xrs even though I asked for premium and the car ran reasonably well. I did not take it over 6,000 rpm.
These days I run midgrade and have been getting good mpgs
Fuel Consumption
Litres per 100 Km .......... 6.66
Miles per Imperial Gallon .. 42.42
Miles per US Gallon ........ 35.32
Kilometres per Litre ....... 15.03
Post pictures of your friend
Iwouldn't recommend regular mid grade is more than OK for me.
My last 8 tanks (since early May) I've downgraded to 89 but have not revved up higher than 6000rpm. I've avg'd 30mpg. Prior to that (Jan-April) I was at 26-27mpg. I probably won't find myself going as far to downgrade to 87. As long as she's not hitting the limiter daily (which I doubt) you're fine dropping to at least 89.
if your friend didnt want the added performance, then why bother with the XRS? at that point go with a base or XR model with the weaker motor, but get better mileage, and do it on cheaper gas.
it's your car, risk it if you'd like but when the owner's manual says premium is "required", not "recommended", it means something ... you're risking trouble in the long run using 89 or lower in an engine were 91 is "required" and with modern engine mgmt systems you may not even know you're developing a problem til its too late ... false economy.
yes 89 is ok...jsut make sure you don't push your car too hard...always shift less than 3000 rpm to save gas as well...
I have used 89 octane. No problems at all.
Will occasionally go with 91 octane when gas prices drop. However, cannot say I noticed much difference. But then again, I rarely ever get past 6,000 rpm.
All you have to do is read sticker on the gas cap access door, look at it on the inside. It Reads; ""Use 91 Octane Premium Fuel Only""
that's right ... and folks don't apparently realize that the damage won't be sudden or catastrophic if you don't use the right grade, but over time you may see the symptoms when it's too late to do anything ... false economy.
It's more likely something would happen to mistas bumper than his engine running 89 octane.
your crystal ball must be in good shape ... and in any case, the diff. in cost between an bumper nick and engine damage is big enough that I'll skip the false economies (cheap gas, cheap oil filters) ... I know a shop owner who has seen that kind of damage.
It kinda comes down to the old saying "if you want to play, you must pay." If you can't afford premium gas, you shouldn't buy a car that requires (as opp. to recommends) premium gas.
I have used 89 as well, could not tell any difference. I like the premium fuels because they are supposed to put additives in that clean your engine as you drive.
