Maintenance advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2008, 12:06 PM   #1 (permalink)
View MiZZr_E's Photo Gallery
Question Maintenance advice?
Hi,
I have a friend who has a 2003 manual transmission MATRIX XR. He's at 130xxx miles now, and I don't think he's ever had any maintenance done on it since purchase in the 50xxx mile range
Is there any lists of what parts should be changed out for the 60k, 120k, or 90k mile marks?
and I already did a search for "90K maintenance," "120K maintenance," and "60K maintenance," with no luck on turning up any info.
any help would be appreciated, so thanks in advance, and thanks anyways if not,
Ted
MiZZr_E is offline   Reply With Quote
Old 07-01-2008, 04:53 PM   #2 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
Hopefully the oil has been changed a few times since the 50k mile range.
Look into getting some fresh tranny gear fluid, clean the MAF sensor, intake, throttle body, and PCV filter.
Check the belt - if it's OEM it'll be a serpentine belt that is prone to squealing in moist weather conditions - might want to replace with a Goodyear Gatorback. Inspect the belt tensioner and water pump.
Check the tires, make sure the steering wheel doesn't vibrate too much @ any speed on a smooth driving area.
Check to see how dirty the air filter is and also the A/C cabin filter - probably filthy and you wouldn't want to breathe in air from that.
XR2003 is offline   Reply With Quote
Old 07-01-2008, 05:06 PM   #3 (permalink)
View toyomoho's Photo Gallery
http://smg.toyotapartsandservice.com/guides.php
Old 07-02-2008, 12:48 PM   #4 (permalink)
msanford's Avatar
View msanford's Photo Gallery
Thumbs up
Originally Posted by toyomoho View Post
That's a great reference!
2004 Matrix Base • FWD • 1zz-FE • Manual • Gislaved Nordftost 5 (NS) 205 55 16
Up-to-date info about my car is here.
msanford is offline   Reply With Quote
