The air intake is on the right hand side of the car partially covered by the hood, indicated in yellow.
Under the hood circled in red is engine side of the air intake.
Hot under the hood air heats the circled in red metal which heats the in coming air. The fix that I did was to remove the plastic and screen air intake part and then using 1" thick foam rubber to insulate the metal. I also blocked off the driver's side of the opening. You can see it when you get it all apart (two screws).
Note I have also insulated my airconditoning pipes under the hood.
