help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2008, 04:33 PM   #1 (permalink)
1wickedtrix's Avatar
View 1wickedtrix's Photo Gallery
help please
hey guys i have an 03 matrix xrs. i have heavily modded it but recently my vvtli has stopped working and my car red lines now at 7000 rpm i can't seem to fix it i've tried just about everything does anyone here know what i'm talking about or experienced this and if so please can i have a few suggestions on what to do
1wickedtrix is offline   Reply With Quote
Old 08-12-2008, 07:50 PM   #2 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
Hmmm, sounds like the safety feature is stuck on. The car normally will redline at 7000 RPM until the engine reaches 65 degrees C. This is so the oil is warmed up enough to reach the lifters or something like that. Maybe a malfunctioning temperature sensor?
TRXR4KDS is offline   Reply With Quote
Old 08-13-2008, 07:14 PM   #3 (permalink)
Trix Owner
Smar969905's Avatar
View Smar969905's Photo Gallery
the lift bolts could be broken as well. if you have replaced the header, or pulled it off at all, then you are in the right area to replace the lift bolts from what i have read, and it is a good idea to, despite that they are a toyota specific part (can't get them at home depot or lowes).
it could also be a bad relay for the oil pressure, or maybe in doing the modifications, you may have done something so a wire is shorting out someplace and the ECU always thinks the motor is not ready to go into lift.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car - Part Time Mod Thule Roof Rack
Smar969905 is offline   Reply With Quote
