the clutch is a hydraulic assist. this means that when you push on the clutch pedal, there is a pump that pushes the clutch fluid (typically the same as brake fluid, which is usually a DOT 3) and helps to separate the gripping face. by increasing the fluid being pumped in, this will help push more on the clutch, and thus take less effort on your part.
on the other hand, it could also be the spring that is attached to the clutch pedal. i used to drive a 1990 camry with a manual, and once i got my 03 matrix xrs, i noticed right away that the clutch pedal was stiffer to push on, and the clutch would grab off the floor.
2003 Matrix XRS-6MT-Black Sand Pearl-Castrol Syntec 0W30 European Formula
Mods - 18" Incubus Paranormal wrapped in Toyo Proxes4 - T-Max Style front body kit - Escort Passport 9500i...what a friend to have in the car  - Part Time Mod Thule Roof Rack
