Home made projectors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2008, 12:44 PM   #1 (permalink)
View Ericss81's Photo Gallery
Have anyone tryed to put projectors on their Trix? Do u know if the headlight is glued, baked or whatever its called. My Q is how hard is to open the headlight?
Ericss81 is offline   Reply With Quote
Old 08-19-2008, 01:16 PM   #2 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
They're easy to open up. If you search, you'll see that some members have painted the chrome inside the headlights, black. Some have done projectors as well. To open them up you first preheat the oven to 350 degrees then turn it off. Place the headlight (1 at a time, 2 won't fit)on a towel and place in the oven for about 10 minutes. Then remove and start prying them apart. To put them back together, fit them together the best you can then repeat the oven process then remove and squeez them back together as tight as possible, A web clamp helps here,
TRXR4KDS is offline   Reply With Quote
Old 08-19-2008, 01:47 PM   #3 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
Preheat for 250 degress and leave it for 7 minutes.....350 is way high it will def melt the headlights....i just recently did mine 250 is good enough
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 08-23-2008, 12:27 PM   #4 (permalink)
Any suggestions about the projectors? People say Acura TL has the best and tend to agree. They are a bit more expensive though compare to TSX for example. What do u think?
Old 08-23-2008, 03:48 PM   #5 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
http://matrixowners.com/?showtopic=74187
XR2003 is offline   Reply With Quote
