Originally Posted by mistamatrix
^lol. X3 headlights will not solve his problem.
Changing the signal bulb from amber to white is easy. Replace w/ bulb that produces a white light!
Can you clarify what you mean by "parking light"? Do you mean lowbeam?
And when you say "separate" the parking light and the signal light, do you need them to work independently of each other?
Thanks for all your reply.
Yes Mistamatix is correct. X3 headlight will not solve my problem.
As yo said changing the amber signal light is easy. No it is not low beam. They have a separate light as parking light but I am not sure of the use of it. Even in the matrix 2007 repair and service manual (a pdf file I have) shows that parking and signal light are same and work together.
Yes they want me to those two lights work independently from each other.
Only way it seems is to drill a hole on the headlight and put another light as parking light. I have contacted a garage in Oslo and he say he has done it and he is ready to do it for me. I am bit scared as he also tells me there is a little risk of breaking the headlight. That's why I am looking for other alternatives. But if I do not find one soon, then I have to take the risk.
