Only one way to turn off a Check Engine light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2008, 06:40 PM   #1 (permalink)
2004 Celica GT Owner
bloda01's Avatar
View bloda01's Photo Gallery
MUST I use a OBDII Scan tool or is there another way?
bloda01 is offline   Reply With Quote
Old 10-24-2008, 08:46 PM   #2 (permalink)
XR2003's Avatar
View XR2003's Photo Gallery
Hopefully after getting the CEL code read.
You can turn off the CEL by the Scan tool
OR remove the negative terminal from the battery for about 5 minutes.
OR removing the ECU fuse from under the hood for about 5 minutes.
XR2003 is offline   Reply With Quote
Old 12-01-2008, 06:04 PM   #3 (permalink)
View blkmatrix2003's Photo Gallery
I've done the battery thing. The light stayed off for about a day. See my earlier post.
blkmatrix2003 is offline   Reply With Quote
Old 12-06-2008, 06:30 AM   #4 (permalink)
bloda01's Avatar
My check engine light was on because the wife forgot to tighten the gas cap. My solution was simple, I tightened the gas cap (it clicks) then the light went away by itself, in less than a week.
Old 12-06-2008, 06:44 AM   #5 (permalink)
Rick F.'s Avatar
View Rick F.'s Photo Gallery
Ditto on going away by itself. The computer will continue to monitor the condition that threw the code and, if it no longer exists, will reset the CEL after a predetermined amount of time in most cases.
On my 4Runners, I can pull the EFI fuse for a few minutes to reset the CEL. If the condition remained, the CEL would come back on after about 20-60 miles.
Here in the States, Autozone autoparts stores will check the code at no charge and typically reset the CEL.
'08 4Runner Sport (new)
'00 4Runner SR5 - Deck Plate Mod, Bilsteins, FIAM Highway Blasters, Sylvania Silverstars (Lows), Hella MicroDE's w/Hella Yellowstar Fogs, Brembos w/PF pads
'07 Mustang GT - MT w/3.55's, Steeda CAI & Brenspeed tunes, 275/40/18 Eagle F1's on SVT Cobras
Rick F. is offline   Reply With Quote
Old 12-06-2008, 07:17 AM   #6 (permalink)
bloda01's Avatar
Interesting.
By the way, I was afraid that disconnecting the battery would cause my radio to trip a theft protection circuit, and require a code to reset it.
Old 12-06-2008, 06:37 PM   #7 (permalink)
edbso's Avatar
View edbso's Photo Gallery
Just take it to an autoparts store and they will read the code and reset. They all do it around here and it is for free!!
edbso is offline   Reply With Quote
