Top 2. nononono Top 3. Becuse there are 3 stpes to the operation of a mottor. intake, power, exhaust.
Im old school. less glow more go. Top 3 mods on ANY CAR.
Intake - This includes but is not limited to: Forced induction, filters, pipes, MAF's Throttel bodys, manafolds, superchargers, trubo's if u can fit them and any bypass vales/idel air controlers.
Fuel and spark dilivry - most over looked mod. i dont care how fly your turbo or intake is. more air means more gass. and if u dont have it when u want it you might as well put the stock intake pipes on. simple fuel upgrades can be a stronger pump, larger rail. biger injectors, new computer or chips. as for spark, dont skimp out on preformance plugs or wires, or even coil packs. a better spark can help a lot when you have a lot of fuel and air in a small spot. just an example porche use's 2 sparkplugs for one cilinder on some 911 models, just to get the most preformace out of there engine.
exhaust - the wounders of back preshure is somthing rocket scintists have been working on for years. and as a result, its wise to consider many many many manafolds before useing one. as a result its not uncomon to see stock exhaust manafolds out preforme aftermarket ones. so look before you leep. but after that HAVE FUN! the best case is no case, Just a strait 12 inch diamiter pipe out the back. its true a 13inch diamiter pipe will out preforme a 12inch pipe but at that point you just geting out of hand. (that was a joke, dual catback systems, larger pipe systems all help a lot. but its up to you and the sound you like. so my advice is to ignor the ADDS 5 HP!!!! tag on the box and just pick one you like.)
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
