Your knock at idle is most likely your belt tensioner. Toyota issued a service bulletin addressing this issue which involves replacing the belt tensioner with an updated part. I would run the engine without the belt to see if the knock goes away, if the knock goes away with the belt off then the tensioner is the problem.
****don't run the engine for more than a minute without the belt as the water pump isn't rotating and could cause the engine to overheat.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
