Originally Posted by edbso
uhm no. those prices are wack.
Anyways OP, you messed up big time not doing anything besides oil changes. Your engine isn't everything. Now honestly you could neglect the coolant, brake fluid, power steering, water pump, timing belt, spark plug, etc. But engine oil and transmission fluid are big ticket repairs.
First you said your car broke down, what exactly broke down?
Second you need to start your car and while its running, pop the hood, take out the transmission fluid dipstick and see what color it is (use a paper towel). If its black and smells like toast, your screwed. Odds are if you change brunt transmission fluid, the cars tranny will suddenly break and if you dont change it, your car will break eventually.
Although if your car broke down because you neglected the transmission fluid, your going to need to rebuild the tranny, changing the fluid alone at that stage wont help.
