'03 Matrix / Vibe, what usually goes bad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2009, 05:31 AM   #1 (permalink)
View camrydud3's Photo Gallery
Hi all,
I'm thinking of purchasing a used '03 Vibe, stick, 2WD, ~100k.
From reading forums, websites, etc it seems like the most common mechanical complaint is the slipping serpentine belt, that's fixed with a Gatorback brand.
I've also heard of a few people having their clutches go out.
1. Other than that, what are some of the more common failures on the '03 Matrix/Vibe?
Since the 1ZZ-FE has a timing chain, and given the mileage, this is the best list I could come up with for inspect/replace, given the mileage. Please feel free to add to the list if you can think of anything else:
- fluids (coolant, oil, gear oil, brake fluid, hydraulic fluid, PS fluid)
- serpentine belt
- belt tensioner (thanks mikered30)
- spark plugs
- thermostat
- water pump
- air filter
- pcv valve
- tires
- battery & alternator (possibly)
- O2 sensor (thanks dasspr)
- MAF sensor (cleaning; thanks dasspr)
- inspect and clean throttle body
- inspect CV boots
- inspect brakes
- check alignment
- check clutch
- inspect CAT (emissions check; thanks dasspr)
Thanks!
- camrydud3
camrydud3 is offline   Reply With Quote
Old 03-21-2009, 08:26 AM   #2 (permalink)
dasspr's Avatar
View dasspr's Photo Gallery
I think your pretty much covered!
dont forget the CAT + 02 sensor + MAF, cat & 02 usually go bad after 80,000 miles in any car
dasspr is offline   Reply With Quote
Old 03-21-2009, 08:49 AM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $533067
Not only are the serp belts bad, so is the tensioner.
mikered30 is offline   Reply With Quote
Old 03-21-2009, 04:17 PM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Can't says anything bad about the car.
Frank@toronto is offline   Reply With Quote
Old 05-12-2009, 12:45 PM   #5 (permalink)
View Fruitbat's Photo Gallery
Good post - I'm looking at an 03 as well, and this is helpful.
About the serpentine belt tensioner - is there a flawed design, or just bad build quality? Does it need to be replaced with a retrofit, DIY hack, or just an OEM replacement?
Old and Busted: '84 Camry LE <2S-E> || '89 Celica GT-S <3S-GE> || '91 Camry LE <3S-FE> || '95 Camry LE V6 <1MZ-FE>
New Hotness: '08 Matrix XR <1ZZ-FE>
Fruitbat is offline   Reply With Quote
Old 05-12-2009, 01:28 PM   #6 (permalink)
Gearhead
Gameroom cash: $196215
^^^ Probably a little of everything here - bad design, spotty build, bad luck. I've seen some "modified" tensioners that actually have removed the little "shock" and went to a solid design. Not a good idea IMO - since it was designed to be dynamic with belt tension.
Most of the time, the tensioner is OK - just slap on a new belt (Goodyear Gatorback) and for 90% of the folks out there - no more squeaky belt, noises under the hood.
Old 06-02-2009, 05:00 PM   #7 (permalink)
View snsrushing's Photo Gallery
I have a 03 with about 60k on it and so far so good. The only problem I did have, now that I think about it, is the drivers side caliper started to seize on me, but that was a relatively cheap fix, even for a shop to do it.
This is my 2nd 1st gen Matrix XR and I love it, just the look of the front end with the factory body kit did it for me.
snsrushing is offline   Reply With Quote
