8 led lights straight from the battery, ok? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2009, 07:45 AM   #1 (permalink)
View matrix_28's Photo Gallery
I want to do some lighting inside my trix and is it okay to directly connect 8+ led lights straight from the battery? I'll be putting like maybe 3 switches to control them! Or if you guys have suggestion where to get a 12v connection without connecting them to the battery itself! My matrix is an '06! Thanks!
matrix_28 is offline   Reply With Quote
Old 03-27-2009, 07:18 AM   #2 (permalink)
View Kanata_Matrix's Photo Gallery
yes you can but ad a fuse or switch will help
Kanata_Matrix is offline   Reply With Quote
Old 03-27-2009, 02:12 PM   #3 (permalink)
Yes, ill be putting on/off switch but what fuse?
Old 03-29-2009, 05:24 PM   #4 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
It's easier to just tap into a circuit in the fusebox like the accessory one. The LED's don't draw enough current to really make any difference. Like the others said, add an inline fuse.
TRXR4KDS is offline   Reply With Quote
Old 03-29-2009, 07:06 PM   #5 (permalink)
Where can i find this fusebox? Is this under the hood on the driver side? Or under the steering wheel?
Old 03-29-2009, 07:26 PM   #6 (permalink)
TRXR4KDS's Avatar
If you're doing interior lighting, use the one inside, under the steering wheel. Or just tap into the 12v accessory plug either on the dash or under the console. I did both, centre console for the cupholder LED's, and the dash for the front footwells and over the HVAC LED's.
Old 05-12-2009, 12:38 PM   #7 (permalink)
View Fruitbat's Photo Gallery
x4 on using an inline fuse. You don't want an unfused connection directly to the battery - if it shorts out or anything you could be looking at a real risk of fire and/or serious damage to your electrical system.
Old and Busted: '84 Camry LE <2S-E> || '89 Celica GT-S <3S-GE> || '91 Camry LE <3S-FE> || '95 Camry LE V6 <1MZ-FE>
New Hotness: '08 Matrix XR <1ZZ-FE>
Fruitbat is offline   Reply With Quote
