Need new engine! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2009, 12:45 AM   #1 (permalink)
View amc_martin's Photo Gallery
Need new engine!
I have a 05 matrix xr the egine started knocking really bad.. im wondering what other cars share the same engine and from what year? i would like to be able to just pull the old one and drop a replacement motor in without any modifications or anything... I know the corollas have the same engine im more wondering about what years will be the same.. thanks a lot,
Martin
amc_martin is offline   Reply With Quote
Old 08-18-2009, 07:46 AM   #2 (permalink)
View Kanata_Matrix's Photo Gallery
05 to 08 is all the same. You can also fit 03-04 but the throttle body is different. What do you mean by knocking? Good luck.
Kanata_Matrix is offline   Reply With Quote
Old 08-18-2009, 11:14 PM   #3 (permalink)
XRS
View mistamatrix's Photo Gallery
Don't forget about the Pontiac Vibe.
Celica as well (00-05).
mistamatrix is offline   Reply With Quote
Old 08-27-2009, 08:33 AM   #4 (permalink)
XRSs'n
Corolla_reps's Avatar
View Corolla_reps's Photo Gallery
i say just get a 2zz-ge engine better for your taste..
TRDXRS...
Corolla_reps is offline   Reply With Quote
Old 09-01-2009, 11:07 AM   #5 (permalink)
View Fps_Hunter's Photo Gallery
gen 7
my friend's 03 celica gts just got his back end smashed in by a drunk driver, the engine works fine, so i say if you want to do a 2zz swap, my friend has one with around 110k miles on it... then again, im in California too
Fps_Hunter is offline   Reply With Quote
Old 04-19-2010, 10:07 PM   #6 (permalink)
View mukker's Photo Gallery
I just picked up an engine from local wrecker for $1000.00. It has 20,000km. I shoped around a bit and there are lots out there around 50-60,000 km.the vibe engines are also compatible.I am told you may have to use your own intake and exaust manifolds though.
mukker is offline   Reply With Quote
Old 04-22-2010, 08:09 AM   #7 (permalink)
View matrixmaster's Photo Gallery
1zzfe
Martin
Hi
You can use 03-08 Corolla or Matrix/Pontiac Vibe if your care is 2wd. You would only need to change the throttle body over the manifolds are the same for 05-08 Matrix.If you have AWD you must use an engine from a AWD Matrix 03-06. The blocks are different for the AWD.Hope this helps!
matrixmaster is offline   Reply With Quote
