Rear wheel bearing hub replacement
hello ...
I could use help figuring out the sequence to remove the rear wheel bearing hub assymbly on a '06 Matrix XR (AWG, with ABS). The (12mm?) bolts from the inside of the flange appear pretty unacessable without either a special tool, or the axle being pulled inward, away from the flange, so a socket can properly seat on the nuts. Might it say what size the axle nut is? I don't have one that size and will need to get one from the shop I'm getting the bearing assymbly from.
Thanks in advance for your help!
Dennis
