Ideally, a good sized pile of money, seriously. Lower boost or moderate boost levels, still going to be fairly costly - not just in parts and fabrication - but the end tuning that you need to make this all work.
Chances are - that intake will have to go, unless you can get the intake relocated easily. Catback exhaust, probably can re-purpose, may need to some welding/cutting - depending on the turbo manifold you choose.
Even with a modest bump in power - you'll have to make sure the rest of the car will be able to handle the additional stresses. This means looking at suspension upgrades, tire and wheel packages, beefing up the transaxle (automatic - possible valvebody work, definitely an oil cooler / manual - upgraded flywheel (depends on ultimate power goals, definitely better friction disc and pressure plate). Definitely need to upgrade the brake friction material, no sense going fast or quickly if you can't slow down.
Condition of the engine itself - need to find out if the engine is healthy enough to take even low boost. If it runs well and has good compression - probably a good candidate for boost. But keep in mind, your pushing the engine beyond original design specs. Even though engineers "bake" in an extra bit of strength here and there - eventually, the boost will break the engine. How long? Depends on how you have it tuned.
Lots of stuff that I'm not alluding too - you need to do some research as well and carefully consider all your options. Don't get pulled in the idea that low boost means "cheaper" or "safer" - boost is boost, to get something that puts out reasonable amount of power and can be used in a daily driver - it will set you back a good chunk of change. Think on the order of $3000-$5000 a the typical investment figures. Note that doesn't include maintenance, need to use higher octane fuel, replacement for parts that are pushed beyond design spec, etc.
