The manufacturer's bumper to bumper warranty is 36 months/36,000 miles - but what you are experiencing would be under the manufacturer's powertrain warranty, which is 60months/60,000 miles.
There were a few Matrix/Corollas that exhibited a sudden no start / no run condition that was traced back to faulty ECMs. Those would generally be replaced under the powertrain warranty. I would suggest that this be brought into a Toyota dealership to start the paperwork trail.
If you do a search online, it seems that there were specific batches of cars that were more susceptible to having this condition than others. The problem with the ECM were poor interior solder contacts to a damaged PCB inside the ECM from the DBW system (impedance mismatch, faulty wiring, faulty components - don't know, Toyota takes the bad ECMs back). Only a replacement ECM will fix this - the dealership will run a diagnostic to confirm this.
Quite a few member running 2005+ Corolla and Matrix models have run into the exact issue, and almost all of them had the ECM replaced under warranty.
