Weird dash light issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2009, 04:34 PM   #1 (permalink)
View ventsyv's Photo Gallery
Question Weird dash light issue
When I start the car at night (03 Matrix XR) and turn the lights on, the lights on the transmission leveler do not turn on right away. If I put the car in gear and drive for a few feet the lights do come on.
Any ideas??
ventsyv is offline   Reply With Quote
Old 03-03-2010, 10:11 PM   #2 (permalink)
View ionshards's Photo Gallery
My car ('03 Manual Base) does the same thing. When I turn the car on at night, put it in gear, and take the brake off (which turns the lights on), the dash lights take a second or two to turn on, usually after I've driven a few feet.
Not really sure why, but it might just be an '03 quirk. You're not alone.
ionshards is offline   Reply With Quote
Old 03-08-2010, 05:07 PM   #3 (permalink)
View ROLLAYOTA1980's Photo Gallery
hmmm havent noticed it on my 03 let me see if it happens to me
ROLLAYOTA1980 is offline   Reply With Quote
Old 05-28-2010, 11:50 PM   #4 (permalink)
View wmcot's Photo Gallery
My daughter has a 2002 echo that does the same thing. If she turns the dimmer all the way down and then back up, the lights next to the shift lever are out. If she puts her foot on the brake pedal and takes it off, they turn on - weird???
wmcot is offline   Reply With Quote
Old 06-24-2010, 08:20 AM   #5 (permalink)
The Matrix has you...
View PA Firefighter's Photo Gallery
USA
I think it has something to do with the Daytime running lights/auto-turn on feature. If you're E-brake is on, your lights stay off because there could be a switch to control it, not 100% sure. If you're parked, with the brake on, you dont really need your lights, do you? Disengage the brake, the car's computer knows you're about to start to drive, and it turns the lights on. I don't have this problem as I did the DRL disable. My headlights are only on when I flip the switch on the stalk.
'03 XR - Lunar Mist, AEM Short Ram Intake, Borla Catback Exhaust, Vibrant Strut Tower Brace, Tein S-Tech Springs, De-badged Hatch, TYC Black Tail Lights, LED Front Signals, LED Rear Lighting, I-Series Stubby Antenna, DRL Disable, 17" Gloss Black Falken Torque 5 wrapped in Falken Ziex Ze 912
PA Firefighter is offline   Reply With Quote
Old 06-24-2010, 02:57 PM   #6 (permalink)
That's a good thought, except her 2002 model doesn't have the auto turn on feature on the lights.
Old 03-13-2011, 03:01 AM   #7 (permalink)
OK. The gearshift lights finally went completely out. Replaced the bulb and no more problem. No idea why they would work when the brake was pressed????
