More likely to be a worn endlink or swaybar bushing - known to wear out for some owners. A worn strut isolator or spring seat, worn upper strut mount can also cause noise (excessive slop). Can also be the exhaust manifold heat shield flexing from the chassis flexing. would have to take the wheel off and do a visual inspection of what their condition is first.
The digital clock has been an issue for both Corolla and Matrix - not much you can do about that other than replacing it. Never seen a taillight lense pop out like that - they do stick out a little bit, but not that extreme. Do you notice any water condensation inside the housing? Headlamps were a weak point on both the Corolla and Matrix - even the previous 8th generation Corolla.
Not sure exactly what the deal is, but on my 1996 Camry - it has all the original lamps on there, save the dome lamp. Lighting is still pretty bright - nothing special about the bulb, just a COTS Sylviania bulb. I'm pretty sure it has something to due with the DRL system that were mandated on all new cars. Extra heat + greater likelyhood to cloud the headlamp lenses may have shorted their lifespans.
I also have the sagging hatch struts - much to my dismay. More than a few occasions have I open the hatch, only to have it either stop partway up or worse, sag downward, and end up crashing my forehead into the edge of the hatch. Looked at having them replaced by the dealership wants a little more than $180 a set, cheapest online was $60 each. Someone had mentioned that they used one for some other application, nearly the identical lift cylinder - just has a different mating end, for $12 each - but misplaced that link somewhere.
No worries about the rest of the car - as there are quite a few Matrixes with more than 100K+ miles, many with 200K+ miles, and even a few with 300K+ miles. Just keep up with the maintainence and you will have no trouble loading the miles on there. Have 110K+ on the Matrix, 160K+_on the Corolla - neither one has a major issue, just these little nagging things.
