Rough idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2010, 09:52 AM   #1 (permalink)
View 05TRDTrix's Photo Gallery
Rough idle
I just bought a '05 Matrix TRD and it seems to me that it idles a little rough compared to what I expected from a Toyota. Is a noticable vibration normal in these cars?
05TRDTrix is offline   Reply With Quote
Old 01-03-2010, 03:05 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $533067
Are talking about bad motor mounts or the tach needle bouncing?
mikered30 is offline   Reply With Quote
Old 01-03-2010, 07:19 PM   #3 (permalink)
The tach doesn't bounce. Just a vibration. Are engine mounts typical to fail?
Old 01-03-2010, 07:35 PM   #4 (permalink)
mikered30's Avatar
Not normally. Have someone step on the gas with their foot solidly on the brake and stand to the side to see how the engine reacts.
Old 01-03-2010, 08:30 PM   #5 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
the motor mounts are not a common issue. how many miles are on the car? is the car just load.........or is it running rough.these motors have a timing chain and they are kind of load and messy sounding.........you could clean your idle air control valve......while you are at it you should clean the maf also.......has any maintenance been done? sparkplugs?
*a common issue with thses cars are the serpentine belt tensioner.......when it is on the way out ....it sounds like a jar of marbles on the passenger side of the engine compartment....
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 01-04-2010, 12:28 PM   #6 (permalink)
The car only has 57,000 kilometers on it (36k miles). It seems to vibrate more under load - if you put it in nutral it steadies out somewhat but there is still a vibration. The plugs on the car are original and no other service work has been done except for oil changes and tires/alignment (got all service records).
I did clean the MAF, PCV and throtle body but as far as I can tell it is DBW so no access to the IAC unless its located somewhere else???
Another question, how long can you go in these between oil changes. The records that I have indicate that changes were done between 7,000 and 9,000 kms, does that seem a little late?
Old 01-04-2010, 04:03 PM   #7 (permalink)
mikered30's Avatar
There is no IAC valve on DBW throttle bodies. Can you inspect the serp belt and tensioner?
Old 01-04-2010, 04:31 PM   #8 (permalink)
I can inspect it but what should I look for? Could it cause a vibration?
Old 01-04-2010, 05:29 PM   #9 (permalink)
mikered30's Avatar
Check for squeaks and deflection in the serp belt when running. They are so poorly designed they can cause a vibration. There is a TSB for the tensioner but that really doesn't help much as you are out of warranty.
Old 01-10-2010, 09:43 PM   #10 (permalink)
yotatrix's Avatar
View yotatrix's Photo Gallery
I wonder if the motor mounts were replaced with polyurethane ones, they tend to vibrate more
2003 Toyota Matrix XRS
2010 Toyota Corolla S
yotatrix is offline   Reply With Quote
Old 01-11-2010, 08:25 AM   #11 (permalink)
Its been so cold up here (-35C) recently that I haven't had a chance to check anything. I'll take a look at it this week since its much warmer now. I pretty sure that it doesn't have poly mounts in it. I don't think this car has been modified in any way. If I find that there is a problem with the tensioner or otherwise I'll take it in since the car still has waranty - previous owner bought an extended plan.
I've noticed that it is a lot less noticable lately but there is definately still a vibration, more than what I would expect from a Toyota anyway. I'll let you know how it goes.
Old 01-11-2010, 06:14 PM   #12 (permalink)
I took a look at the belt today and it looks fine - seems to run smoothly. I've noticed that this car isn't getting the gas milage that I expected. Is it possible that it could need new plugs? The manual says that they are good for 190k KMS. But that would also explane the rough idle.
Old 01-13-2010, 08:34 PM   #13 (permalink)
mikered30's Avatar
Could be, I would pull the plugs and take a look at them.
